Fuel pump replace/upgrade - Mustang Evolution
Old 11-19-2014, 10:03 AM   #1
The_Chech's Avatar
So this morning I came off duty and when to start my car to head home and the car won't start. Tried to jump it thinking since it got into the 20's battery may have drained. This wasn't the case car wanted to turn over but seemed like it was getting fuel. So I turned it all off and tried the listen for the prime of the fuel pump and it was dead silent. Did the obvious things looked at the fuses under the hood and I mean I looked at every single one lol I wanted to be sure. Then I thought it was the gravity red button thing in the rear, what ever it's called May have been tripped. Again it was depressed all the way so that wasn't the case. I'm starting to wonder is it really now the fuel pump?
If it is the case after I get done probing around with a volt meter.
What is every one doing to upgrade the fuel pump? I plan on going FI later on and since the fuel pump might be out and I have to replace it, what should I replace it with? I've heard the SVT focus fuel pump? Or should I just go OEM with a Boost A pump while I'm messing with it? Haven't really done to much research on this matter as I was holding off on this for awhile.
Need to get this fixed pronto but I can wait a week if some thing like a high rate or lph fuel pump needs to be ordered.
Thanks in advance
The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 11-19-2014, 12:21 PM   #2
phillip433's Avatar
Well if you hold down the trip meter button on the dash for 5 seconds and while holding it turn the ignition on, it will give you different numbers, one of those is your fuel pressure, see if there's fuel pressure. If not could be million things why it doesn't turn over for example such as the camshaft sensor or crankshaft sensor. Something silly like that. Idk just my 2 cents.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 11-19-2014, 12:25 PM   #3
phillip433's Avatar
One of the reasons you couldn't hear the pump is that it could've already had pressure in the lines.
Old 11-19-2014, 12:42 PM   #4
The_Chech's Avatar
I did the little digital tack thing and couldn't tell which one was the fuel pressure. And wouldn't a camshaft sensor trip a check engine light?
Old 11-19-2014, 12:57 PM   #5
phillip433's Avatar
Yes it would. So I'm assuming you don't have any codes popping up.
Well you could unplug the switch to the fuel pump which is right between the gas tank and the bumper... Hook a meter up to it and see if you get any power. It's easy. Just have to reach up in there and pull the wiring down. That would be the only way to se if the pump is getting power.
If not. Just wait couple hours for the lines to lose it's pressure and turn the key on to see if you hear the priming.
Old 11-19-2014, 01:24 PM   #6
The_Chech's Avatar
I do not. Wish it did because it would help me pin point what's going on. And that was my next thing to do with a volt meter but now I have to work on getting it towed but that may be a hassle on its own.....
And does any one know what the stock pump pushs out? I've done a little bit of searching seen motorcrafts for 362$ BBK has a 300 lph one for 319$ don't mind BBKs products, not my first choice but...
Old 11-20-2014, 05:44 AM   #7
Speed_Mister's Avatar
Region: Arkansas
I got an aviator fuel pump rated 310lph for 50$ from eBay for my nitrous car. 1 year and over 30,000 miles still good!
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 11-20-2014, 05:53 AM   #8
Region: Arkansas
Buy a new fuel pumps on eBay, I found 255 lph fuel pumps for 37$ new. AM is trying to make money from that high price crap.
Full Bolt Ons
370rwhp 470rwtq
Old 11-20-2014, 07:04 AM   #9
The_Chech's Avatar
Figured it was way more then it's worth for BBKs
Old 11-20-2014, 08:24 AM   #10
The_Chech's Avatar
So I checked the gauge again on dash for fuel pressure it says it's at 112
Old 11-20-2014, 10:48 AM   #11
phillip433's Avatar
So you know there's pressure in the fuel lines ... Well another easy way to see if there's fuel in the lines is. Take one of your fuel injectors out and see if fuel comes out of it.
---------- Post added at 05:48 PM ---------- Previous post was at 05:47 PM ----------
Then you will know it's not a fuel problem and begin diagnosing ignition problems
Old 11-20-2014, 01:23 PM   #12
The_Chech's Avatar
Pretty sure it's my inertia button it's depressed but I took it out to pop it and it won't and the ball in it isn't moving. So I think it tripped an broke
Fuel pump upgrade. FastEddie03GT 1996-2004 Mustang GT 1 10-27-2014 05:46 PM
Fuel pump upgrade? DtrMustang 2005-2010 Mustang GT 0 07-21-2013 07:44 PM
Fuel pump upgrade Terminator 2005-2010 Mustang GT 8 06-28-2013 08:50 AM
im about to replace my clutch/flywheel what else should i replace? 1996v6stang Pre-2005 V6 Mustang 2 07-12-2010 11:22 AM
04 3.9 mustang Fuel pump upgrade Zebs5408 Pre-2005 V6 Mustang 3 03-28-2010 02:29 PM
10:20 PM
