Gears! - Mustang Evolution
Old 11-19-2014, 05:35 PM   #1
Boosted_3v's Avatar
Gears!
What gear set up this look like to you guys it's a auto Click image for larger version
Name:	ImageUploadedByMustang Evolution1416443733.901808.jpg
Boosted_3v is offline   Reply With Quote
Old 11-19-2014, 05:41 PM   #2
Mile high JDF's Avatar
Probably 4.10s. The best way to tell is jack up the rear end, mark a line on the driveshaft, spin the tire one full revolution, and count how many times the driveshaft rotates
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-19-2014, 05:43 PM   #3
Isn't that normal. My V6 auto sits on 2500 at 70
Old 11-19-2014, 05:48 PM   #4
04beautyGT's Avatar
Is the speedometer corrected, assuming 4th gear? Also, this is a super odd question, like what are you accomplishing? Anyway, it's probably 3.73's if the speedometer is corrected. I believe manuals with 4.10's at 70mph is 2500RPM.
04beautyGT is offline   Reply With Quote
Old 11-19-2014, 05:51 PM   #5
There are calculators online you can use. Plugin your tire height, 4th gear ratio, the mph and and the gears, then it spits out rpms at that speed, so just put in common gear ratios to find it.
The auto does have a higher OD ratio, like .74 or something, so rpms will be higher than the maual with the same rear gears
Old 11-19-2014, 07:00 PM   #6
The abs light is on maybe his rear speed sensor is bad..... At least thats what my scanner says since my abs light is also on
Old 11-19-2014, 08:21 PM   #7
04beautyGT's Avatar
I was referring to the fact the when you change gears it throws the speedometer off (if getting lower gears, the gauge shows a lower speed than you are actually going). I don't really know how all the sensors and lights are hooked up, so I have no clue if that could be something or just something completely different
Old 11-19-2014, 08:22 PM   #8
04beautyGT's Avatar
@ Joser714;
Old 11-19-2014, 08:24 PM   #9
Boosted_3v's Avatar
It's a auto
Old 11-19-2014, 08:53 PM   #10
@ Joser714;
Oh yea i knew about how changing gears can throw off the speedo (this is not the first gear thread on mevo) I thought you wear referring to the light like i thought
Old 11-21-2014, 01:22 PM   #11
Mfore33's Avatar
Well I have a 2000 gt auto and that is where my tach runs at 70 and I bought the car new off the showroom floor with the 3.73 upgrade.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
05:38 AM
