Weird noise - Mustang Evolution
Old 11-20-2014, 07:10 PM   #1
joe_117's Avatar
Weird noise
Okay guys, it just started doing this but here's basically the problem.
There is this noise that occurs when my rpms go after 3000 and up.The higher the rpms I go, the faster this noise goes. It's a squeaky type high pitch noise.
joe_117 is offline   Reply With Quote
Old 11-20-2014, 07:33 PM   #2
fenixignition's Avatar
in gear? in neutral? belt maybe. possible vacuum leak, but idk about a squeak.
2002 GT 5sp. 16x,xxx miles
Old 11-20-2014, 07:41 PM   #3
joe_117's Avatar
If I rev it up the noise occurs. The higher the rpm is the faster the noise makes in gear as well
---------- Post added at 02:41 AM ---------- Previous post was at 02:41 AM ----------
Old 11-20-2014, 07:45 PM   #4
same with the clutch in and out? id stick my head under the hood and listen closely to different areas. listen for cracked hoses, timing chain, belt, and just move the throttle body to give it gas and raise the rpm. hopefull you can narrow down an area that the sound is comin from. otherwise if its the speakers, it could be caused by the alternator, or a power cable running along the ground wire if you have a system.
Old 11-20-2014, 07:50 PM   #5
Blogger
99ford's Avatar
I'd guess it's a belt
Old 11-20-2014, 07:52 PM   #6
joe_117's Avatar
I think it is the belt. It has to be because the more gas I give it the faster the noise makes.
Old 11-20-2014, 08:01 PM   #7
Look closely at the belt. Does it have tiny cracks in it?
Old 11-20-2014, 08:07 PM   #8
joe_117's Avatar
I did not see any, but if there was a way I could post a video that would help tremendously
Old 11-20-2014, 08:35 PM   #9
Billgluckman's Avatar
Get under the hood and push the throttle. Is the noise coming from the belt or not? Pretty easy to diagnose...
Billgluckman is offline   Reply With Quote
Old 11-20-2014, 08:41 PM   #10
joe_117's Avatar
Name:	ImageUploadedByMustang Evolution1416541242.299184.jpg
It's coming from the bearings on the alternator.
Old 11-21-2014, 03:08 AM   #11
Refurb or replace.
Sent from my LG-D800 using Mustang Evolution mobile app
Weird popping noise from rear iwannagofast 1996-2004 Mustang GT 1 05-12-2009 12:10 AM
Weird noise electricstang Pre-2005 V6 Mustang 17 06-20-2006 06:29 AM
weird noise.. white 98 gt 1996-2004 Mustang GT 0 12-11-2005 05:55 PM
weird noise... project232 Pre-2005 V6 Mustang 5 04-13-2005 08:28 AM
OMG.. WEIRD.. so weird.. wiarumas The Bar 14 02-17-2005 12:45 PM
09:00 PM
