Going into gears - Mustang Evolution
Old 11-20-2014, 07:13 PM   #1
joe_117's Avatar
Going into gears
I'm just curious on this. When I go to 1st, 2nd,3rd gear it won't shift smooth. Yes I push the clutch all the way, and sometimes it just goes into the gear smooth. But other times I feel like there's something in the way so I have to give it a little more nudge.
Any idea what it could be? Or is it normal?
joe_117 is offline   Reply With Quote
Old 11-20-2014, 07:18 PM   #2
joe_117's Avatar
I have stock clutch, shifter, etc
Old 11-20-2014, 07:19 PM   #3
What year is the car? Helps future out which transmission you have.
Old 11-20-2014, 07:20 PM   #4
joe_117's Avatar
2001
Old 11-20-2014, 07:23 PM   #5
fenixignition's Avatar
im betting tr3650 with store brand merconV, possibly hasn't been changed in a while, or recently changed and overfilled.
2002 GT 5sp. 16x,xxx miles
Old 11-20-2014, 07:25 PM   #6
joe_117's Avatar
I got this car man, and do not know what kind of clutch is in it. Probably stock
Old 11-20-2014, 07:31 PM   #7
we need the year of your stang to determine. but if you just got the car like this, then i would start with changing the fluid. if it has a 3650 tranny, 3.2 quarts of pennzoil synchromesh is what most would reccomend. you can use mobil1 synth. ford says MerconV, but i wasnt happy with it in mine. too much fluid im pretty sure can cause at least 1-2 and 2-3 to be a hassle to put in gear.
Old 11-20-2014, 07:33 PM   #8
joe_117's Avatar
Oh my mistake yes I did do an oil change I used penzoil.
The car runs great but the shifting doesn't feel right. Sometimes it goes into the gear smooth sometimes it use a little kore force to put it in the gear
Old 11-20-2014, 07:34 PM   #9
The 3650 they put in the 2001 is notorious for bad shift forks. They fixed it in 2002.
I put my money on that
Old 11-20-2014, 07:43 PM   #10
joe_117's Avatar
Any way I can fix that?
Old 11-20-2014, 07:44 PM   #11
Transmission rebuild with upgraded forks
Old 11-20-2014, 07:45 PM   #12
joe_117's Avatar
Ugh....don't know where to start
Old 11-20-2014, 07:48 PM   #13
keep readin through the forum. theres plenty of old posts talking about different tranny issues and such. you may stumble upon some descriptions that might match whats goin on with yours and give you better leads. thats how i fixed a few things in my car.
Old 11-20-2014, 07:49 PM   #14
I've got the same issues. My 3rd gear does not like to go in at all under heavy acceleration. Its hit or miss if it will get blocked or if it will go in.
Old 11-20-2014, 07:51 PM   #15
joe_117's Avatar
That's the thing tho, when I launch or Just going slow it takes a little force sometimes to shift
Old 11-20-2014, 09:20 PM   #16
When you changed the transmission fluid, exactly how many quarts did you refill it with?
And what brand of transmission fluid did you use?
Old 11-20-2014, 09:23 PM   #17
phillip433's Avatar
I say it's the clutch fork. How many miles is on the car ?
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 11-20-2014, 09:25 PM   #18
phillip433's Avatar
Going into gears
Or they put an aftermarket clutch in or clutch cable and it's not adjusted right. I had to hassle this with my 03 gt and I just gave up and upgraded to a t56 and a brand new clutch and clutch cable.
Old 11-20-2014, 10:31 PM   #19
V6 stang's Avatar
When my v6 was doing that (hard to shift, feels like blockage) it ended up needing a new clutch. I think it was the pressure plate messed up? Idk. But it's a diff transmission too. Just thought I'd throw my 2 cents in. Change the trans fluid to Mobil1 synth @3.2 qts and see how it goes. Cheap and easy way to see if it's somethin more serious or nt.
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 11-21-2014, 12:46 PM   #20
Lorraine's driver
ab_mach1's Avatar
I'd say it's the synchro's. The TR3650's are nown for being notchy and 'nibbling' gears when you shift. I'd check to see what clutch quadrant you have. If it's stock (plastic) it could be cracked or flexing when your putting the pedal down. This could cause the clutch to not disengage completely. Same could be true if you're cable is stretched or fraying. The stock setup is spring loaded and self adjusting. It's pretty well known on the Mach 1's anyway, that when you are accelorating to redline, your stock quadrant and cable can be the cause of missing shifts or being 'blocked' from shifting in to gear. Getting an aftermarket quadrant (aluminum) and able will really help this. If you already have an aftermarket quadrant and cable, it could need to be adjusted just a bit. As mentioned in this thread, 3.2QTs of Mobile 1 synthetic ATF or Penzoil stuff is a better choice that what was in the tranny OEM.
Instagram: @ab_mach1
Old 11-21-2014, 01:04 PM   #21
Billgluckman's Avatar
Well mine is the same way. When I first bought the car I swapped fluid for royal purple and installed a new quadrant and adjustable cable. I couldn't tell any difference.
Mine is the t45 though.
Billgluckman is offline   Reply With Quote
Old 11-21-2014, 01:35 PM   #22
Lorraine's driver
ab_mach1's Avatar
Royal Purple is notoriously bad for the synchros of the TR3650. It messes with them somehow. I noticed that it got worse when I tried it in mine. Not sure if it's an issue on the T45's.
2004 Azure Blue Mach 1
IG: @azurebluemach
Old 11-21-2014, 05:04 PM   #23
IG: @azurebluemach
Well..in all honesty, about 6 months ago I had my tail housing off and when I put it back together I used the cheapest ATF I could find. I did this because I assumed it couldn't get any worse than it already was.
When I got it all back together I thought the trans shifted much better. It's still far from smooth though.
Old 11-27-2014, 04:27 PM   #24
SquatchMan's Avatar
Check your throw out bearing
04 GT
SquatchMan is offline   Reply With Quote
Old 11-28-2014, 11:59 AM   #25
Cbird's Avatar
Region: Iowa
Going into gears
IG: @azurebluemach
The myth is that it eats away at the rings in the transmission. From several hours of researching this topic a month ago and talking to several representatives of both Tremec and Royal Purple I've concluded its just a myth backed with little to no evidence.
Royal Purple of course says it's fine to use. Tremec says they have never tested it, not even once and have no idea about the long term effects.
I have synchromax in my 05 and 09 and have only positive things to say about it. Over 70k on my 05 with that fluid by the way, so if It does cause damage it might take awhile. I don't see It happening though because nothing in the fluid is even remotely corrosive. Who knows?
Cbird is offline   Reply With Quote
Old 11-28-2014, 12:00 PM   #26
Cbird's Avatar
Region: Iowa
Going into gears
My bad. The app hates me.
Old 11-28-2014, 12:17 PM   #27
Just switched to pennzoil synchromesh, and oh man, it shifts like i thought a manual was supposed to. (This is my first manual) i ended up putting 3.4~3.5 qts in because 3.0 my transmission makes a loud noise in 5th constantly. 3.2 it makes noise til its hot. And 3.5 it makes noise when its cold out and goes away after a mile or so. Everywhere i searched, everyone shrugs off that grinding "wet rocks in a tumbler" noise. So idk
Sent from my LG-D800 using Mustang Evolution mobile app
trans going into "limp mode"..... rinfield2004 1996-2004 Mustang GT 3 10-25-2013 12:38 AM
Shift hard when going into 3rd gear. M_Wag 1996-2004 Mustang GT 7 11-04-2012 03:21 PM
Going into gear problems ashpow24 2011-2014 V6 Mustang 10 08-21-2012 01:22 PM
Noise going into gears bradh2414 Pre-2005 V6 Mustang 5 07-20-2011 03:46 AM
So...how much trouble am I going to get into? lowflyn The Bar 12 04-14-2009 06:33 PM
11:42 PM
