Dome light won't shut off - Mustang Evolution
Old 11-21-2014, 01:14 PM   #1
Mfore33's Avatar
Dome light won't shut off so I've removed it for now. I'm pretty sure the switch has gone bad in the door latch. Has anyone taken the latch out and replaced/repaired it? I would like to fix this so my battery doesn't run dead. Thanks in advance for any help and suggestions.
Old 11-21-2014, 01:18 PM   #2
natestang07's Avatar
Was the switch all the way up?
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-21-2014, 01:26 PM   #3
Mfore33's Avatar
No. It started randomly blinking on while driving and shutting the door again would make it go off for a while but it would come back on.
Old 11-21-2014, 02:58 PM   #4
1996mustang's Avatar
Probably is the relay for it. Happened on my caprice dome stayed on
Sent from my SGH-T399N using Mustang Evolution mobile app
Old 11-21-2014, 05:10 PM   #5
Try cleaning the switch and using silicon lube on it. My car (04 gt) did the exact same thing. The switch was stuck on mine. I used WD-40 and Silicon spray lube and have not had anymore issues.
Bluebyyou04 is offline   Reply With Quote
Tail Light Shut Off swiTch FullyAutomatic 1996-2004 Mustang GT 16 03-27-2014 05:24 AM
Passenger Airbag Off light won't shut off rotors 2011-2014 V6 Mustang 4 03-28-2013 04:57 AM
578 dome lights to 578 42mm led dome lights? Sluder4 Pre-2005 V6 Mustang 5 03-10-2013 05:51 AM
Hood won't shut. New latch needed? Bryan02V6 Mustang Paint, Appearance & Detailing 13 09-10-2012 01:18 AM
02:28 AM
