p0190 code - Mustang Evolution
Old 11-24-2014, 10:01 AM   #1
p0190 code
i recently had my car not start and it thru this error code p0190
fuel rail pressure sensor circuit A replaced the frps and car started fine. drove about 10 miles, shut car off. Would not re-start. tries to, but seems like it is not getting fuel as same code thru again. waited 15 minutes, car started right up, ran fine. got home, put in garage, went out yesterday, started right up, pulled out of garage. 2 hrs. later went to put back, would not start. did not throw code this time, waited 30 minutes, started right up. I'm nervous to drive anywhere for fear of not starting back up. Fuel pump? Relay ? not sure what to check next. any suggestions?
bricky is offline   Reply With Quote
Old 11-24-2014, 10:32 AM   #2
Lorraine's driver
ab_mach1's Avatar
Man, theres a ton of info on this on AllData. I'm not really sure where to go next with it, so I'll post a few tests.
Instagram: @ab_mach1
Old 11-24-2014, 10:39 AM   #3
Lorraine's driver
ab_mach1's Avatar
This might help...
It said check for vacuum leaks as well
There's so much, I can't post it all. Basically, you want to confirm there is nothing wrong with your wiring that it's not open somewhere. then vacuum leaks, etc.
Old 12-15-2014, 07:42 PM   #4
xfree143's Avatar
Did you find the problem? Mine is doing the exact same thing, it's driving me crazy.
xfree143 is offline   Reply With Quote
P0190 code anyone? Mathew r Wright 1996-2004 Mustang GT 22 03-06-2016 02:18 PM
Codes p1233 and p0190 help please. Speed_Mister 1996-2004 Mustang GT 2 05-17-2013 12:27 PM
P0190 code! Mathew r Wright 1996-2004 Mustang GT 0 11-20-2012 09:15 PM
P0190 DTC HELP! MiGT01 1996-2004 Mustang GT 5 03-18-2012 06:37 AM
Code P0190 PLEASE HELP CodyNelson 1996-2004 Mustang GT 0 01-27-2012 07:43 AM
06:42 PM
