Shuts off & Idles low - Mustang Evolution
Old 11-24-2014, 04:07 PM   #1
Luccette_GT40th's Avatar
When I'm at complete stops the car begins to struggle then shuts off!
The service and battery light turns on right after. (WTF)
I bought with intake manifold installed already so I believe that is part of the problem (I think) Help needed.
I'm live in Orlando, florida and would like to take it in to a Ford know it all person without having to pay an arm and a leg please..
Any suggestions???
Thanks for looking!
Luccette_GT40th is offline   Reply With Quote
Old 11-24-2014, 04:09 PM   #2
2004 GT needs a mechanic soon please.
Old 11-24-2014, 06:42 PM   #3
Which intake manifold does it have on it?
Im not sure if you're asking for recommendations for a good mechanic in the Orlando area or if you would like us to help you diagnose your stalling problem?
Old 11-24-2014, 08:25 PM   #4
May need both actually if we can't pinpoint what the issue is...It has the same manifold used by Ford on the 2001 to 2004 4.6L SOHC 2V V8 GT Mustangs
I forget to add that it came with STEEDAs air intake kit already installed.
Sent from my SAMSUNG-SM-G900AZ using Mustang Evolution mobile app
Old 11-24-2014, 08:28 PM   #5
And Thank you for responding straybullit!
Old 11-24-2014, 08:40 PM   #6
Also the only way I can prevent it from shutting off is by turning on my A.C !
Old 11-24-2014, 08:44 PM   #7
Mile high JDF's Avatar
I would bet your IAC is going bad. Stray might know he the proper way to diagnose it, I can't think of it off the top of my head, but that seems like it'd be the most likely culprit to me
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-25-2014, 05:52 AM   #8
if your CEL light is on, hook up a scanner and it will tell you what's wrong or at the least point you into the proper direction.
Hello is offline   Reply With Quote
Old 11-25-2014, 06:06 AM   #9
HELLO The CEL light only comes right after it shuts off..never while driving. Will the scanner still work in this case??
Also my stang is automatic so when I take it off from park to drive it jerks (sometimes) ...thank you for the info
Old 11-25-2014, 07:09 AM   #10
The cel goes off when you restart the car? You could still try to scan it as it may have codes stored.
I would also check for vacuum leaks
Old 11-25-2014, 07:20 AM   #11
Right, Not ight comes on when I restart it. When I toke it to Autozone all I got was a bad battery read.
Thanks again though
---------- Post added at 02:20 PM ---------- Previous post was at 02:19 PM ----------
And I'll look into the leaks..haven't done that yet
Old 11-25-2014, 12:27 PM   #12
If you have a bad battery or a weak alternator, all sorts of strange problems can occur. I'd make sure that the charging system is working correctly first.
If that is working correctly, and the idle problem still persists, I agree with JDF that the next likely suspect would be the Idle Air Control valve.
Old 11-25-2014, 12:40 PM   #13
Roger that, will replace the battery as well as look into the alternator...will check back.
Thanks again Stray
Old 11-25-2014, 10:04 PM   #14
Steve96's Avatar
Like stray said it sounds like charging system issues. I have read many posts on this forum where odd issues like your having can be traced back to the alternator.
1996 GT
Old 11-26-2014, 09:03 PM   #15
fenixignition's Avatar
sounds like a vacuum leak, maybe even something up with the throttle body. if the ac saves it from dying, wouldnt that mean that the extra throttle from the iac is keeping it going? still very well possibly that its an iac issue, but it sounds like a vacuum leak if its constant. spray some throttle body cleaner where you think there could be a leak. you should hear a change in the rpm. (place a dime or pennie at the throttle linkage and bolt to give it a little throttle.
and dang, i used to live in orlando, i would check it out if i could.
just need some more info. how long has it been doing this?
did something change and then it happened? (intake manifold?)
or did you buy it with this problem?
2002 GT 5sp. 16x,xxx miles
Help my car shuts off mustangGT5.0 1996-2004 Mustang GT 6 11-15-2012 09:03 PM
K&N 57-2532 air intake, mpg loss, high idles nekronos Pre-2005 V6 Mustang 12 10-13-2012 06:36 PM
Car shuts off when WOT vinnygt Mustang Wheels & Tires 14 12-29-2011 12:02 AM
1988 mustang shuts off? llyr 1979-1995 Mustang GT 0 12-12-2011 01:30 PM
Shuts off and a few questions abrfan 1979-1995 Mustang GT 10 09-08-2006 03:32 PM
04:02 PM
