Could Use Some Help! - Mustang Evolution
Old 11-25-2014, 04:19 AM   #1
Michael.s.king's Avatar
Region: Maine
02 GT automatic that has been running like crap lately.
I have:
- changed the plugs
- did the COP rebuild boot/coil kit
- fuel filter
- cleaned the drop in K&N air filter
- cleaned the MAF
- cleaned the throttle body
- replaced the PCV Valve and the hose that connects to it
It's been skipping all over the place in the RPM range and idling rough. I feel ups and downs (like surges almost) of power when I accelerate, mostly at higher RPMs. The skipping is mostly at the lower RPMs. It feels like there is a loss of power over all. Today it was running really bad and finally threw a code which I haven't checked yet. I know checking this code is a good place to start, but I'm thinking it could be a COP? I will post the code once I get it checked after work.
How can you check to see if it is a COP?
Thanks in advance and sorry for the stupid questions haha
Michael.s.king is offline   Reply With Quote
Old 11-25-2014, 08:08 AM   #2
v8pony's Avatar
First things first if its throwing a code, Check that and get back. A COP could throw a code, it also could not at times...if there is no code thrown and you suspect a COP, than with the car running pull one COP plug at a time, you should hear a change in the sound of your engine/idle, if you pull one and nothing changes, then there it is, plug it back in and pull again to confirm, if no changes than there's your bad COP.
02 GT
2013 Feb MOTM
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-25-2014, 08:11 AM   #3
v8pony's Avatar
O
2002 5spd GT
Old 11-25-2014, 11:58 AM   #4
Mfore33's Avatar
Buy a new cop and replace one and keep moving it until the misfire is fixed. That's what I had to do because it never threw a code
Old 11-26-2014, 03:06 AM   #5
Region: Maine
Got the code check, misfire on start up and misfire on first 1000 revolutions of something like that, cylinder 7. I'm just glad i know where it is! I'll try check the plug and COP.
Can anyone tell me which ones cylinder 7? Haha, driver side third back from the front?
Thanks guys
Old 11-28-2014, 05:08 AM   #6
fenixignition's Avatar
2002 GT 5sp. 16x,xxx miles
I could use some help making up my mind 5pointOh 2011-2014 Mustang GT 11 04-07-2012 07:10 AM
Sure could use some advice! InHymn Pre-2005 V6 Mustang 4 06-01-2011 05:17 PM
anyone with experience i could use some help upton7 General Mustang Discussion 22 05-31-2009 09:09 AM
I could use some advice please upton7 1996-2004 Mustang GT 26 03-20-2009 06:28 PM
Hey yall...could use some help Ashys18 Pictures and Videos 122 11-05-2007 08:40 AM
08:20 PM
