Instrument Cluster malfunctioning - Mustang Evolution
Old 11-25-2014, 05:34 AM   #1
99_GRUMPY_GT's Avatar
Yesterday I was driving home when I noticed that the battery and ABS dummy lights were coming on, the battery light stayed constantly on, but the ABS was blicking every few seconds. Now I know these two lights have nothing to do with the problem but that of a result of my problem.
My cluster and all its guages are malfunctioning. First it started with the battery gauge pegging far right when I accelerated through the gears and then would go back to normal when RPMS are going down from slowing down. And when the RPMS are rising, the aux. components would rise like the A/C, the A/C would blow harder when the battery gauge would peg. Last night the low beams would get ultra high when accelerating. Then the other guages like the tach and speedo would either not move and when they do not move during acceration, they would peg far right during slowing down with no accelerator action, then go back to zero. The gas and oil and temp guages do the same.
Any ideas as to what is causing this mishap?
The alternator was just replaced last month. And there is no CEL to identify this fault.
Thanks
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 11-25-2014, 09:38 AM   #2
Well I checked all fuses and all good. Battery after running around town started to leak fluid from caps and was smoking.
So that told me the brand new alternator was over charging and bad. So I went back to Pep Boys and they hooked up to the battery, which tested good, then the alternator and as I thought tested bad. So they are swapping it out now.
Good thing I saw the battery acid and smoke or much longer and it could of been a messy situation for sure or even worse exploded while I was under the hood and severely hurt myself.
Sent from my LG-D415 using Mustang Evolution mobile app
Old 11-25-2014, 12:39 PM   #3
Where have you been Bill?
I hope that you've been doing well, aside from the alternator.
I had this very same thing happen years ago. My alternator was overcharging and it slowly boiled down the water level to the point where too much hydrogen built up inside of the battery and when I went to start it one time... BOOM!!! The battery exploded! Lol. It actually dented the hood on my truck!
Good to hear from you again and glad you caught the problem in time!
Old 11-25-2014, 02:48 PM   #4
I am doing fine. A while back i started my own business after total boredom set in with my retirement. It took off like nothing I ever expected. I actually had to hire a individual to help keep up with all the work. I may even have to hire another soon. I try to drop in when time allows. Good to hear from you Ron.
2004 Roush Mustang Instrument Cluster BetsyBootstrap Pre-2005 V6 Mustang 3 06-30-2010 12:08 PM
Brake, ABS & Instrument Cluster stevinas 2005-2010 Mustang GT 4 07-01-2008 08:53 AM
Need help on Instrument cluster. Batroo 1979-1995 Mustang GT 4 04-23-2008 09:48 PM
instrument cluster swap pipeguy General Mustang Discussion 0 04-11-2008 09:43 AM
94 - 95 GT Instrument Cluster StreetRacer4371 Mustang Parts for Sale and Wanted 5 10-21-2004 08:32 PM
09:53 AM
