01 GT plenum question - Mustang Evolution
Old 11-25-2014, 07:02 AM   #1
001Gt's Avatar
Not sure what kind of plenum or throttle body i should buy for my 01 GT? Any ideas
Name:	ImageUploadedByMustang Evolution1416924063.167222.jpg
001Gt is offline   Reply With Quote
Old 11-25-2014, 07:02 AM   #2
LeoGMR4558's Avatar
Bbk?
Sent from my iPhone using Mustang E
LeoGMR4558 is offline   Reply With Quote
Old 11-25-2014, 07:07 AM   #3
LeoGMR4558's Avatar
Accufab if you're ballin
Old 11-25-2014, 07:09 AM   #4
001Gt's Avatar
Yeah. What size Throttlebody. 70 or 75
Old 11-25-2014, 07:35 AM   #5
The_Chech's Avatar
Trick flow makes a really decent one and it won't brake the bank it's also 75mm for 109$ on summit
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 11-25-2014, 07:37 AM   #6
The_Chech's Avatar
Id go 75 for plenum would be kinda pointless to go 70mm for the same price as a 75. You'll pick up more power any how with a larger one
Old 11-25-2014, 07:38 AM   #7
001Gt's Avatar
That's good to know thanks.
Old 11-25-2014, 08:30 AM   #8
Cbird's Avatar
Region: Iowa
Whatever you do make sure to replace the plenum because that's the biggest choke on the intake side.
That plenum carried over from the NPI motors.
Cbird is offline   Reply With Quote
Old 11-25-2014, 01:48 PM   #9
fenixignition's Avatar
I got a bbk in mine. I can never remember if its 70 or 75mm. I think 70.
Sent from my LG-D800 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 11-25-2014, 08:12 PM   #10
fomoco4life's Avatar
I'm saving up for this accufab combo... http://m.americanmuscle.com/ac42v75thbop.html
Old 11-25-2014, 09:41 PM   #11
Steve96's Avatar
The Trickflow some have mentioned from summit is the way to go. It's the best bang for your buck and a great quality unit. Accufab is great too but you can accomplish the same thing with the Trickflow and get pretty much the same results.
1996 GT
Old 11-25-2014, 09:43 PM   #12
Bullitt intake FTW
Old 11-25-2014, 10:03 PM   #13
Steve96's Avatar
That is true^^^
1996 GT
Old 11-25-2014, 10:10 PM   #14
2001 Bullitt with only a tune and off-road H pipe
Name:	ImageUploadedByMustang Evolution1416978614.717129.jpg
Old 11-26-2014, 08:20 AM   #15
Attachment 170341
Am i to understand that your low end torque got boosted to around 250hp at 2.5k rpm?
Old 11-26-2014, 08:27 AM   #16
001Gt's Avatar
Name:	ImageUploadedByMustang Evolution1417015637.167851.jpg
Is this a good combo???
Old 11-26-2014, 08:39 AM   #17
The_Chech's Avatar
it is and it will work fine but that's a lot of money for a throttle body and plenum. not trying to pursued you on brands and stuff but TrickFlow makes the same thing and you'll save 100$ or so. Its like 109 for the plenum and 189 for the throttle body. There plenum is a 75mm and throttle body is either 70 or 75mm which either you choose to run
Old 11-26-2014, 08:50 AM   #18
I have that plenum with no issues. My bbk 75mm i just removed. Testing something out with the stock intake, i wanna see if it makes a dif in maf temps in traffic. Long story. But.i kinda noticed the bbk tb was a bit clunky and harder to move.
Also i was told that the plenum makes the intake sound louder.
Old 11-26-2014, 09:16 AM   #19
001Gt's Avatar
I've found out that bbk intakes get really hot!!! Had one on my old v6
Old 11-26-2014, 09:19 AM   #20
The_Chech's Avatar
The reason why im gonna swap out my BBK one for a plastic one.
Old 11-26-2014, 11:04 AM   #21
The great thing about the Bullitt intake is the much broader power band than the PI intake. Torque starts off much sooner with it. It's normal bolt on GT power, but the curve is much better.
Old 11-26-2014, 06:22 PM   #22
Intake manifold? My understanding that the metal. Ones are for racing, cuz regular driving they absorb a lot of heat.
Old 11-26-2014, 06:32 PM   #23
If anything heat is fine for daily driving. You want something that does not absorb hear for racing.
Old 11-26-2014, 06:36 PM   #24
Ah. I thought more cooling was occuring during racing. Is metal intakes mostly to handle forced induction?
Old 11-26-2014, 06:42 PM   #25
Eturner's Avatar
Power wise there is no difference between the 70mm and the 75mm when your just NA!.. Now if your planing FI down the road, go with the 75mm!.. Now as far as any Heat Soak with a metal intake, personally I have not seen any more or less than with the stock one!.. Click image for larger version
Name:	ImageUploadedByMustang Evolution1417052491.429229.jpg
TrickFlow Track Heat intake with 75mm TB on a '04 GT!..
Old 11-26-2014, 06:42 PM   #26
When racing you are often at higher speeds, but that air goes into the radiator to cool the engines coolant, it doesn't do as much for the manifold.
Old 11-26-2014, 06:44 PM   #27
PI intake can take more forced induction than the stock bottom end can. Correct budget friendly combo for a bolt on 2V is the stock PI intake and the TFS plenum/75mm throttle body combo on Summit for $279. Anything else is just wasting money until you get a built motor with a lot of boost.
Old 11-26-2014, 08:21 PM   #28
The_Chech's Avatar
01 GT
They have a sale going on late model for the SVE tb and plenum combo same company that makes the trick flow ones I believe from the looks of it
Old 11-28-2014, 10:10 AM   #29
SVE is a chinese copy of the TFS stuff which is made in the USA. SVE stuff will likely be fine but...
Old 12-03-2014, 03:16 AM   #30
FastEddie03GT's Avatar
I read a book about the 4.6 mustang engine and a group of people would put bolt ons and dyno the engine to see what kind of gains they would get. Accufab did the best in gains but the trickflow plenum was just right behind it. Ive also heard from people to stay away from 75 mm tb unless your going to put a power adder on. Bbk's 70mm tb is a good choice if your just doing bolt ons. I had the trick flow plenum and bbk 70mm tb on mine but never got around to dyno and see what the gains were because i ended up putting a tork tech kit in.
FastEddie03GT is offline   Reply With Quote
T/b and plenum combo question Joeyd5 1996-2004 Mustang GT 22 06-21-2013 06:46 AM
Plenum Question Cornkush 1996-2004 Mustang GT 1 04-22-2013 07:50 PM
New TB and Plenum question imhooked 1996-2004 Mustang GT 5 03-22-2012 09:38 PM
Plenum question + more ;) nickpeck28 1996-2004 Mustang GT 33 12-14-2004 12:28 PM
Pro Ported upper intake plenum on my 4.6L 99+.... Rick0636 The Bar 8 01-15-2004 07:43 AM
08:08 PM
