Transmission Fluid Change - Mustang Evolution
Old 11-28-2014, 01:50 PM   #1
SquatchMan's Avatar
After how many miles an I supposed to change the transmission fluid? It's a 2004 GT with 82,000 on it and I don't know if it's ever been changed. I just bought it this summer. It's a 5 speed.
04 GT
04 GT
SquatchMan is offline   Reply With Quote
Old 11-28-2014, 01:58 PM   #2
If its never been changed probably a good idea to do it now. Especially if it is the manual transmission, they were known to be overfilled from the factory.
Which transmission do you have?
Old 11-28-2014, 01:58 PM   #3
SquatchMan's Avatar
It's a 40th anniversary edition. So whatever they have. I don't have any idea.
04 GT
04 GT
Old 11-28-2014, 02:16 PM   #4
The_Chech's Avatar
It would be safe to say its never been changed then. Its fairly simple to change the fluid on these. Just make sure you fill it back up with 3.2 qts of fluid.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 11-28-2014, 02:28 PM   #5
SquatchMan's Avatar
What brand?
04 GT
Old 11-28-2014, 03:26 PM   #6
The_Chech's Avatar
I'd go with penzoil syncro mesh
Old 11-28-2014, 09:09 PM   #7
fenixignition's Avatar
2002 GT 5sp. 16x,xxx miles
Old 11-29-2014, 07:14 PM   #8
Probably THE very first thing you should do with a 01-04 manual transmission car is drain the fluid out and re-fill it with 3.2 quarts of Syncrhomesh. They were overfilled from the factory to 3.8 quarts which caused all kinds of issues. Most people don't think to change manual trans fluid. I'd say it should be changed relatively regularly.
Old 11-29-2014, 07:18 PM   #9
SquatchMan's Avatar
Ok, thanks! About how regularly?
40th Anniversary GT
04 GT
Old 11-29-2014, 08:22 PM   #10
I'm crazy and always do it once a year. Most ppl who actually change it regularly will do it every 20-30k.
Old 11-29-2014, 08:23 PM   #11
SquatchMan's Avatar
Ok, cool. Thanks!
40th Anniversary GT
04 GT
Old 11-29-2014, 08:33 PM   #12
SquatchMan's Avatar
What's the absolute easiest way to change it? I've read some people pull their shifter and some others do everything from the bottom.
40th Anniversary GT
04 GT
Old 11-29-2014, 08:45 PM   #13
40th Anniversary GT
I did the job in like 15 to 20 minutes via the shifter. Just removed the shifter, lifted the car and stuck a jack stand underneath, loosened the drain plug, dropped the car back down and let it drain, lift again real quick, (jack stand) replaced drain plug, dropped again, and filled 3 quarts from the shifter. Drove it, and mind makes a liud grinding noise in 5th, so I added .2 qts, still had some noise, so I added .3, a total of 2.5 qts, and now it only makes that noise whem its cold. Shifts like I always wished it would since I switched to synchromesh. And being a non synthetic fluid, ill likeley change it more frequently as well.
Old 11-29-2014, 08:47 PM   #14
Pull the shifter, doing it from the bottom is just silly. You can do it literally in 20 minutes via the shifter.
Old 12-23-2014, 12:10 PM   #15
SquatchMan's Avatar
Does it matter if it's Penzoil or Valvoline synchromesh?
40th Anniversary GT
04 GT
Old 12-23-2014, 12:25 PM   #16
They're both good. GM too if you feel like paying out the ***. Pennzoil is $8/bottle at Autozone.
Old 12-23-2014, 12:37 PM   #17
If you can find it ^ I went to 3 different auto stores until I finally went to the Chevy dealer and paid out the *** for it.
Old 12-23-2014, 05:13 PM   #18
I've put many miles on both cars with Mobil1 ATF and a short throw shifter. Works wonderfully.
I know that Syncromesh is also reccomended by Tremec.
-Two choices there from Tremec.
Old 12-27-2014, 10:01 PM   #19
SquatchMan's Avatar
Can you give me a step-by-step on how to change it? I'm gonna change it tomorrow, and I'd like to know the easiest/quickest way to do it. I just don't want to screw anything up, or do it wrong. Thanks.
40th Anniversary GT
04 GT
Old 12-28-2014, 07:30 AM   #20
Perfect timing to slam on a MGW STS
Old 12-28-2014, 09:06 AM   #21
40th Anniversary GT
Drain bolt is on the bottom of the trans, that is self explanatory. When you put the plug back in, do not gorilla tighten it or you can crack the case. Put some black rtv on the plug to ensure a good seal. Fill through the shifter with 3.2 quarts. There are a ton of vids on YouTube of shifter removal or just watch the one on mgws website.
The whole fluid change should be very quick, like a half hour.
Old 12-28-2014, 09:26 AM   #22
MattsGT's Avatar
When you change the fluid through the shifter what kind of gasket do you use? I am planning on installing a MGW shifter and see that it comes with a tube of gasket sealant but have also seen the preformed gaskets. Any thoughts?
2002 GT 5Spd
MattsGT is offline   Reply With Quote
Old 12-28-2014, 10:48 AM   #23
Preformed gaskets suck, they always push out and leak. Use the black RTV, you don't need alot, make sure to go on the inside of the bolt holes, not the outside.
Old 12-28-2014, 10:58 AM   #24
MattsGT's Avatar
Thanks for the info.
2002 GT 5Spd
Old 12-28-2014, 11:25 AM   #25
SquatchMan's Avatar
Thanks!
40th Anniversary GT
04 GT
Old 12-28-2014, 01:28 PM   #26
SquatchMan's Avatar
So I have a short throw shifter in my car, I ripped into it, thinking it would be easy like you guys said. I'm an hour and a half into it and I'm completely lost. What do I do? I've drained the transmission fluid already and I cant get the shifter out
40th Anniversary GT
04 GT
Old 12-28-2014, 03:03 PM   #27
Mile high JDF's Avatar
40th Anniversary GT
Post up some pictures of where you're at. Are you trying to fill through the shifter base?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-28-2014, 03:09 PM   #28
Take out the console part, then there are 4 screws around the dust boot, then 4 bolts holding the shifter in. After that you gotta use some arm muscle to get the stock shifter out.
But yes like JDF said, post some pics.
Old 12-28-2014, 03:50 PM   #29
SquatchMan's Avatar
I ended up buying a pump and just doing it under the car
40th Anniversary GT
04 GT
Old 12-28-2014, 04:38 PM   #30
Did you even watch the mgw video? It literally takes 5 minutes to pull the shifter.
Old 12-28-2014, 04:50 PM   #31
SquatchMan's Avatar
I searched, couldn't find the video
40th Anniversary GT
04 GT
Old 12-28-2014, 04:58 PM   #32
It's on the mgw shifter website.
Old 12-28-2014, 05:04 PM   #33
SquatchMan's Avatar
It probably is, I couldn't find it when I looked though lol
40th Anniversary GT
04 GT
Old 12-31-2014, 11:43 PM   #34
U'll need smaller sized sockets. How to video LINK:
1990-2004 Mustang SHORT THROW SHIFTER
Old 01-01-2015, 12:18 PM   #35
I'm still not quite sure how you get stuck though even without the video.
-Remove shifter knob but just unscrewing it
-Pull out shifter bezel and unplug the 12V wires
-Unbolt the 2 shifter handle bolts and remove handle
-Remove 4 bolts holding on the dust boot
-Remove 4 bolts holding the shifter
-Smack the shifter base a few times to dislodge it or stick a phillips screwdriver in one of the shifter holes and pop it loose that way.
-Pull out shifter.
Takes 5 minutes.
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
TSB Transmission Fluid Change UPDATE pcarman 2011-2014 Mustang GT 11 01-10-2012 02:41 PM
Change Transmission Fluid pcarman 2011-2014 Mustang GT 11 10-01-2011 12:27 PM
transmission fluid/filter change dd96stang Pre-2005 V6 Mustang 2 05-20-2010 09:08 PM
Manual Transmission Fluid Change Gray Ghost 1979-1995 Mustang GT 0 04-11-2009 06:51 AM
09:28 PM
