Belt noise - Mustang Evolution
Old 11-28-2014, 10:02 PM   #1
joe_117's Avatar
Belt noise
Name:	ImageUploadedByMustang Evolution1417237273.744420.jpg
Well guys I put this thing on my belt called belt dressing. At first when I would go it would stop making the squeak noise. Couple hours later I turn my car on and it's 5 times worse. It squeaks when it idles now. When I add the belt dressing on it it stops but just repeats. Any clue on how I can stop this pesky noise?
joe_117 is offline   Reply With Quote
Old 11-29-2014, 01:37 AM   #2
XSlashDashX's Avatar
Replace the belt. Belt dressing does not work.
Old 11-29-2014, 06:02 AM   #3
fenixignition's Avatar
if a new belt still squeaks then you have a pulley issue. the belt conditioner might have been causing it to slide on a pulley easier for a moment. also, last belt conditioner i checked said its for prolonging the life of a new belt rather than fixing old ones. and even then i wouldnt use it.
2002 GT 5sp. 16x,xxx miles
Old 11-29-2014, 10:09 AM   #4
joe_117's Avatar
Thanks , will do.
Old 11-29-2014, 12:23 PM   #5
Mfore33's Avatar
U need a new belt and tensioner puller
Old 11-29-2014, 12:54 PM   #6
I agree on the tensioner pulley but meh on the belt. Mine squeeks for 2 minutes and then it goes away.
Old 11-30-2014, 05:35 PM   #7
If you don't have a new belt then I'm sure that's the problem. Mine squeaks at start up and goes away after a few seconds. My gf old gt belt would squeak and I bought belt dressing thinking it would work. Sure enough it didn't, lol. Bought new belt and problem went away.
5.0, belt route and belt length question. Hatenot SVT Mustang 3 04-04-2014 09:12 AM
Belt Noise BlackSmoke02 Pre-2005 V6 Mustang 21 05-27-2013 10:40 AM
2001 v6 3.8 engine noise after new belt truckdriver0 Pre-2005 V6 Mustang 6 01-03-2013 09:03 PM
engine making belt noise engine ticking sounds like a diesel 3k miles on car Yellow50 2011-2014 Mustang GT 34 05-04-2012 09:56 AM
sounds like a belt but... not a belt!! vwdavid Pre-2005 V6 Mustang 4 09-03-2010 10:29 PM
05:03 AM
