Cant figure out where this tube goes - Mustang Evolution
Old 11-30-2014, 02:49 PM   #1
fenixignition's Avatar
When i got the car, it had a c&l intake. In the trunk was the stock tubing, and that small tube in my hand was attatched to the intake tubing. I replacedthe c&l with the stock and now im left with that extra tube, and a piece of pvc connecting the iac line to the intake tube. I drew lines showing whats connected. Any ideas what this small line went to?
2002 GT 5sp. 16x,xxx miles
Old 11-30-2014, 04:37 PM   #2
04beautyGT's Avatar
I'm not sure, but it's a factory component, so there has to be an answer. My best guess is that may be the same line as the one where the green is drawn on? (maybe the aftermarket one came with that piece?) I just looked at my BBK CAI and it only has two hoses that connect to intake tubing, so maybe an extra piece the other owner found lying around that has nothing to do with the intake? You could also try looking up any the serial number online (if that is a serial number on it.)
04beautyGT is offline   Reply With Quote
Old 11-30-2014, 05:08 PM   #3
Billgluckman's Avatar
Everything is hooked up just fine from what I can see.
Billgluckman is offline   Reply With Quote
Old 12-03-2014, 10:52 PM   #4
Speed_Mister's Avatar
Region: Arkansas
There is a breather tube that goes to both valve cover driver side is easy to spot but intake side valve cover breather is harder to see, might check those.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-04-2014, 05:59 AM   #5
Bingo. Valve cover breather PCV if I remember correctly. I sold my 98 with a 99 PI motor a few months ago and it was last spring when I did an intake change so I'm not 100%.
Old 12-04-2014, 06:59 AM   #6
to clarify, whats on there already, theres a big tube from the iac, to a resonator(?) to the intake tube.
Theres a shorter tube (possibly the same one thats in my hand) from behind the IAC to the intake side valve cover (PCV)
theres a long plastic tube from the drivers side valve cover breather (not a pcv, or at least, just a fitting, no rattling piece) to the intake tube. This piece is just barely long enough, but i figured thats either because of the throttle body, or a replaced elbow.
The rubber hose for the IAC says Ford on it. But i have a piece of PVC to connect it to the intake tube. I do not know what originally connected the two.
So Im guessing for whatever reason, the previous owner had an extra tube for whatever reason. and is missing a fitting to the intake from the IAC. All i know about it, is it was hanging off of the intake tube sitting in the trunk when i bought it and a c&l intake was in the engine bay.
cant figure car out 89lx5.slow 1979-1995 Mustang GT 8 11-17-2012 11:52 PM
Cant Figure it Out saleenman 1996-2004 Mustang GT 3 08-11-2009 05:20 PM
Help Me Figure Out Where This Goes Brent Pre-2005 V6 Mustang 6 09-19-2007 08:32 PM
hidden message in halo 2 cinimatic(figure this out hidden countdown) BrooksPS The Bar 7 07-27-2004 03:05 PM
Help me figure out what this plug was for. Dom Mustang Audio & Video 9 07-14-2004 08:18 AM
10:55 AM
