Shifter gasket - Mustang Evolution
Old 12-01-2014, 09:10 AM   #1
robin_gt's Avatar
Shifter gasket
Hi folks i just ordered a short throw shifter for my 02 gt and i was wondering if i need a new gasket.
Thanks in advance
robin_gt is offline   Reply With Quote
Old 12-01-2014, 09:13 AM   #2
phillip433's Avatar
No. You can just go by a liquid seal type thing from an auto store and put it on the the shifter before you place it.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 12-01-2014, 09:14 AM   #3
The_Chech's Avatar
Heard making your own is also one of the better ways to go about sealing it back up. And I think the other one was a cobra bob gasket?
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 12-01-2014, 09:16 AM   #4
phillip433's Avatar
The only bad thing is, if you make it yourself. It's extremely hard to get off. It's more like glue lol
Old 12-01-2014, 09:18 AM   #5
fenixignition's Avatar
yea, it takes a small crow bar and a wrench for leverage.
2002 GT 5sp. 16x,xxx miles
Old 12-01-2014, 09:23 AM   #6
sten37's Avatar
I would recommend it. They can't be much and you don't wanna do it again if the old one leaks after you put the shifter in!
Ben
sten37 is offline   Reply With Quote
Old 12-01-2014, 10:20 AM   #7
robin_gt's Avatar
Thanks for the reply.
Yea thats a good idea with the liquid seal thanks for the idea!
Old 12-01-2014, 10:21 AM   #8
robin_gt's Avatar
Thanks for the idea with the liquid seal. Prob gonna do that.
Old 12-01-2014, 10:53 AM   #9
I've heard that the cobra bob gasket works great, but the american muscle one leaked for someone else.
Also, i think the gasket set is mostly for dampening a little bit of tranny noise. I have the stock shifter on mine right now while i try to figure something out with my steeda tri-ax. probably just apply some rtv, let it dry, then add a little before i install it, that way it has a nice rubbery gasket to press on, and a little bit of it still wet so it forms a tight seal.
Old 12-01-2014, 01:12 PM   #10
The_Chech's Avatar
This actually sounds good in theory I might have to try this when I get my MGW shifter later this December
Old 12-01-2014, 09:21 PM   #11
Mile high JDF's Avatar
The Cobra Bob gasket works good. The AM knock-off is nowhere near as good as the CB gasket.
Just run one thick line of RTV and call it good. Trying to build up a layer like that runs the risk of the first layer getting contaminated and not bonding properly to the new layer.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-01-2014, 09:28 PM   #12
Shifter gasket
I just use a black silicone sealant/gasket maker for mine. Can get it at places like Autozone or Oreillys.
Old 12-01-2014, 09:46 PM   #13
Tried the CB gasket and it leaked. Run a bead of black rtv and you'll be fine. Whoever is saying its hard to get off... Remove the bolts, stick a Phillips screwdriver in one of the holes and pull back and it'll pop free every time.
The gasket is supposed to be for sound deadening anyway but if you get the mgw shifter and use a fresh rubber boot and the included piece of dynamat it'll be damn near silent anyway.
Sent from my VS980 4G using Mustang Evolution mobile app
2000 Mustang GT Steeda #0048
Old 12-04-2014, 07:31 PM   #14
robin_gt's Avatar
what do you mean by running a bead of rtv? do you mean like whole line around it or a line of beads?
Old 12-04-2014, 08:10 PM   #15
Even line
Sent from my GT-P3113 using Mustang Evolution mobile app
Old 12-04-2014, 08:13 PM   #16
You've never heard the term "run a bead of rtv"?
Old 12-04-2014, 08:15 PM   #17
robin_gt's Avatar
Nah haha
---------- Post added at 09:15 PM ---------- Previous post was at 09:14 PM ----------
Even line
Ok cool thanks
Old 12-05-2014, 04:55 PM   #18
robin_gt's Avatar
Im trying to get the old shifter off right now and its in there man any tips or tricks?
Old 12-05-2014, 05:29 PM   #19
Pry bar and a wrench or something for leverage. On the left hand side i had the best spot. Hold the wrench down there to push against the metal of the car, and pry upward, leaning on the wrench. It takes a little wiggling but eventually it pops loose. I think scottydoesntknow says stick a screwdriver in one of the bolt holes and pull it to the side and it should pop off. I havent tried that.
Sent from my LG-D800 using Mustang Evolution mobile app
Old 12-05-2014, 05:37 PM   #20
Like I said in a previous post, stick a Phillips screwdriver in one of the rear holes and pull towards you. It'll pop the shifter free.
Old 12-05-2014, 05:58 PM   #21
robin_gt's Avatar
thanks for the help guys
got it popped off with a small pry bar you guys rock
Old 12-05-2014, 11:20 PM   #22
XSlashDashX's Avatar
Or do it like the mgw video said. Smack it. Lol!
Gasket for Shifter Foxone 1996-2004 Mustang GT 2 03-27-2013 11:48 AM
shifter gasket questions mattyp511 Pre-2005 V6 Mustang 2 02-20-2013 08:53 PM
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 11:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 03:24 AM
05:01 AM
