Springs - Mustang Evolution
Old 12-01-2014, 01:39 PM   #1
to_oaxaca's Avatar
Region: Nevada
Springs
So i have these tein springs that I wanna install to my 00 gt , they say that its okay to be used on stock shocks, should I just install them like that or should I save up for shocks and struts?
Name:	ImageUploadedByMustang Evolution1417466364.552755.jpg
2000 Convertible GT
93 Octane Bama Tune
to_oaxaca is offline   Reply With Quote
Old 12-01-2014, 03:42 PM   #2
Steve96's Avatar
You can probably get away with your stock struts/shocks for a while depending on how worn they are now. I would save up and get a good quality set of shocks/struts like the Koni STR.T or Tokico HP.
1996 GT
Old 12-01-2014, 06:31 PM   #3
The_Chech's Avatar
What he said. Start saving now and get caster camber plates (Maximum Motorsport) and start saving up for some better struts and shocks you will thank your self if you do it.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 12-01-2014, 06:35 PM   #4
to_oaxaca's Avatar
Region: Nevada
I was thinking of getting some K&Ns from AM, dont know if theyll support the drop
2000 Convertible GT
93 Octane Bama Tune
---------- Post added at 06:35 PM ---------- Previous post was at 06:35 PM ----------
Okay thanks, im kinda new to all of this
2000 Convertible GT
93 Octane Bama Tune
Old 12-01-2014, 06:42 PM   #5
The_Chech's Avatar
Ideally you would want to install caster camber plates at the same time to help get your alignment set right after you install the springs. Since it looks like the springs you got only drop about 1.5" or so you'll be fine for a bit. But I highly recommend getting some plates with in the next 2-4 months so you don't wear out the inside of your tread
Old 12-01-2014, 06:44 PM   #6
I've heard those springs are garbage. I think someone on here had a set and hated them
Old 12-01-2014, 07:09 PM   #7
Agree 100% ford racing C springs or the Sr performance springs if you want a nice drop without breaking the bank I've had good luck with both sets. Eibach is the way to go if price isn't an issue
Bigshow14 is offline   Reply With Quote
Old 12-01-2014, 07:33 PM   #8
02_gt's Avatar
Instead of the caster camber plates you can buy some camber bolts from am and it will help your alignment for the time being
02_gt is offline   Reply With Quote
Old 12-01-2014, 08:51 PM   #9
Mile high JDF's Avatar
The S-Techs actually drop 2.5" if I remember right.
CompOrange had them on his V6, I think the reason he hated them was because the front sat higher than the rear.
OP you can run those without upgrading the shocks and struts for a short amount of time but at a 2"+ drop things tend to wear out very quicky.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Cut springs to H&R Springs Slow4V 1996-2004 Mustang GT 4 10-16-2014 02:03 PM
BMR springs vs Ford K Springs Rolltide 2011-2014 Mustang GT 5 08-01-2012 09:57 PM
Lowering springs or factory springs fordracing63857 1979-1995 Mustang GT 3 06-27-2012 08:42 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
07:42 PM
