How much RWHP/RWTQ can the stock clutch handle? - Mustang Evolution
Old 12-02-2014, 03:44 AM   #1
Speed_Mister's Avatar
Region: Arkansas
Never heard a set number on how much the stock clutch can handle on a dd. I'm putting down about 460-470RWHP and about 440-450RWTQ. Did 3 races racing and I smelt a little bit of my clutch. What clutch would you all recommend, I don't mind a stiff clutch, I don't have chicken legs. Lol.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-02-2014, 04:52 AM   #2
WheelStander's Avatar
Mcleod rxt....twin disk soft as butter.
Rst if you cant afford the rxt.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 12-02-2014, 08:29 AM   #3
About 400whp plus the clutch is going to be older and probably worn if its original. What year are you? Because the 99 Cobra and everything else from 01-up had 11" flywheels vs the 10.5" of 00-down so you'll want to upgrade to an 11" clutch/flywheel if your car didn't come with that size originally. You will not need to modify anything else and you will want a new flywheel anyway with a new clutch.
I've also edited out the street racing portions of your post. Any talk of street racing whatsoever is not allowed on the forum.
That is COMPLETE overkill for what he is doing. If he's on stock internals he's already on the ragged edge as far as the rods holding up. An Exedy 11" Mach 400 is rated for 500ft lbs and will be totally fine.
Old 12-02-2014, 08:48 AM   #4
I always do it up right.
Old 12-02-2014, 09:53 AM   #5
You on a stock bottom with the 515whp?
Old 12-02-2014, 09:54 AM   #6
Nope
Old 12-02-2014, 10:15 AM   #7
Guess I'm not going to do my fuel upgrade to go higher though so stuck...515 is fine with me I guess.
Just can't justify the cost when it runs like a top now.
Old 12-02-2014, 11:26 AM   #8
Region: Arkansas
I've got the 2004 with the tr-3650 so 11 inch it is.
Full Bolt Ons
370rwhp 470rwtq
Old 12-02-2014, 11:29 AM   #9
Region: Arkansas
And I thought rods didn't give out till about 400rwhp. I guess I'm a 25 more of a shot from that.
Full Bolt Ons
370rwhp 470rwtq
Old 12-02-2014, 03:18 PM   #10
You have to have a dead nuts spot on tune and keep the RPM at 5600-5800 at most for the stock rods to hold up close to the 500whp level but people do it. Smart tune is to have the same dead nuts tune at 400-425 on the stock rods but if you want to rebuild later on anyway...
Yes you have an 11" clutch but it really doesn't matter since you should buy a new flywheel anyway and going from 10.5" to 11" is a simple matter of a flywheel/clutch combo. Like I said I'd get the Exedy Mach 400 if you don't have a built motor. Rated for 500ft lbs but make damn sure you properly break it in first. Lots of stop and go and no beating on it for 500 miles which is hard (I just broke one in over the summer).
New RWHP & RWTQ numbers Wildstang86 2011-2014 Mustang GT 7 08-15-2014 10:42 PM
RWHP and RWTQ estimates Wildstang86 2011-2014 Mustang GT 45 08-09-2014 09:05 PM
2011 Mustang GT 414 RWHP / 391 RWTQ Brent 2011-2014 Mustang GT 22 06-04-2011 05:45 PM
399 RWHP/434 RWTQ Stock 3.8 Auto Twin Turbo @ 14psi justin00stang Pre-2005 V6 Mustang 23 02-28-2005 09:16 AM
10:42 PM
