Help very confused - Mustang Evolution
Old 12-02-2014, 04:29 PM   #1
behemoth's Avatar
Region: Oregon
Help very confused
So I have had a issues with anti freeze leaking into one of my spark plug wells tore down the intake manifold and found that there's a missing bolt hole in the manifold so it's not sealing all the way maybe I'm crazy and this normal but wouldn't there be a hole for a perfect seal
Sent from my SM-N910T using Mustang Evolution mobile app
ID:	170783   Click image for larger version
behemoth is offline   Reply With Quote
Old 12-02-2014, 04:53 PM   #2
mineralgt's Avatar
There is not a bolt that goes there. The heads are actually cast the same left and right and are interchangeable so if it were on the drivers side that hole would go to the thermostat
mineralgt is offline   Reply With Quote
Old 12-02-2014, 04:54 PM   #3
mineralgt's Avatar
Also make sure you have the intake gaskets on the correct sides they are different left and right
Old 12-02-2014, 04:59 PM   #4
behemoth's Avatar
Region: Oregon
Well I'm pretty sure I had them right cuz there's Lil holes that gasket connects to just having issues cuz my wells keep filling with antifreeze
Old 12-02-2014, 05:07 PM   #5
behemoth's Avatar
Region: Oregon
Could this be siqn of cracked head?
Old 12-02-2014, 09:43 PM   #6
Take better pics... Where was it leaking from? Do you have a metal crossover? If not, get a new intake. If you do have a metal crossover, is coolant seeping out from where it bolts to the plastic? All the plastic intakes fail after awhile, just a matter of when. Never get a used one, never get a doorman or non Ford PI unit. The correct replacement is $215 on AM/LRS.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 12-02-2014, 10:01 PM   #7
behemoth's Avatar
Region: Oregon
I just got a new pi one from am from ford racing it's leaking in the back buy heater and the plugs are getting wet on both sides. I put this one on replacing a cracked one that broke at cross over can't seem to get it figured
---------- Post added at 05:01 AM ---------- Previous post was at 05:01 AM ----------
Yes on metal cross over
Old 12-02-2014, 10:04 PM   #8
behemoth's Avatar
Region: Oregon
Side
Old 12-02-2014, 10:05 PM   #9
behemoth's Avatar
Region: Oregon
Heater
Old 12-02-2014, 10:06 PM   #10
behemoth's Avatar
Region: Oregon
Gasket
Old 12-03-2014, 07:43 AM   #11
Hmmm you could have a warped head but are you sure that the heater hoses or nothing else back there is leaking and its for sure the intake?
Also are you properly torquing it to 22ft lbs and in the correct torque sequence? You can't just bolt it on and tighten it down any old way.
i'm very confused!!!!! 91BlueMule General Mustang Discussion 78 03-12-2012 01:21 AM
BUSTED! very very very slight WW Tbird232ci The Bar 6 12-18-2005 01:54 AM
Very Very clever! Ken The Bar 4 05-14-2004 05:40 PM
So there I was....... (very very long) Ken The Bar 19 10-15-2003 04:47 AM
06:53 PM
