I am soo Tired of this idle problem Help please - Mustang Evolution
Old 12-03-2014, 12:20 AM   #1
samcrored's Avatar
00 gt ...5 speed...ok first and foremost . Changed IAC twice. checked for any and all vacuum leaks..none. New TPS. good gas. so been having a coming to a stop problem for a long time now and i hate it. But this is what confuses me. Yesterday i came coasting(clutch not pressed just in neutral to a stop and the rpms dropped super fast! all the way to 100 or less...lights came on dash and everything i immediately pressed in clutch and it saved it and the rpms jumped right back up. It has only died completely once and that was because i didnt push in the clutch. ALso if i let it drop to about 1000 rpms then puch in clutch idle will drop smoothly. I am so over this car . I absolutely can not figure it out. any help please i would be great full as this is my daily driver!
samcrored is offline   Reply With Quote
Old 12-03-2014, 12:30 AM   #2
Speed_Mister's Avatar
Region: Arkansas
Hmm usually I see problems about high idle problems then you'd install a copper cap in the iac tubing with an 7/16th hole drilled in it. You may need to turn your idle screw about an 1/8th of a turn.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-03-2014, 12:31 AM   #3
samcrored's Avatar
sometime it will idle high at around 2k, but when it drops...it drops.......and dipps well below 500 sometime almost dying
Old 12-03-2014, 12:48 AM   #4
Region: Arkansas
I would put the copper plug with a 7/16 hole drilled in it and stick it in the tubing and turn the screw 1/8 of a turn, so the blades open more.
Full Bolt Ons
370rwhp 470rwtq
Old 12-03-2014, 12:49 AM   #5
samcrored's Avatar
wouldnt the copper plug make it drop even faster?
Old 12-03-2014, 12:50 AM   #6
Region: Arkansas
I had high rpm hangs and did the copper iac. Mod and it fixed the problem.
Full Bolt Ons
370rwhp 470rwtq
Old 12-03-2014, 12:50 AM   #7
samcrored's Avatar
Yeh but do you think that would fix the idle dropping fast as hell and dipping way below 500?
Old 12-03-2014, 12:51 AM   #8
Region: Arkansas
Yes make sure you drill a hole in it first, a 7/16 hole, and make sure you get all metal shavings out before installing.
Full Bolt Ons
370rwhp 470rwtq
Old 12-03-2014, 12:53 AM   #9
Region: Arkansas
It sure hell will keep it from hanging, and then I would adjust idle screw 1/8 a turn opening the blade more.
Full Bolt Ons
370rwhp 470rwtq
Old 12-03-2014, 12:54 AM   #10
samcrored's Avatar
i understand what you are saying i had thought about doing that, but i figured if the rpms dropped faster than they allready do it would still dip below 500 rpms at a light.
---------- Post added at 02:54 AM ---------- Previous post was at 02:53 AM ----------
so its probly from hanging, and then dropping so fast from a hang thats causing the dip?
Old 12-03-2014, 12:54 AM   #11
Region: Arkansas
Adjusting the idle screw will keep idle from dropping so low, copper plug helps keep from hanging Rpms.
Full Bolt Ons
370rwhp 470rwtq
Old 12-03-2014, 12:55 AM   #12
samcrored's Avatar
i am going to try that. I am just at a standstill so i would probably pretty much do anything at this point hah
Old 12-03-2014, 12:56 AM   #13
Region: Arkansas
Probably from hanging Rpms.
Full Bolt Ons
370rwhp 470rwtq
Old 12-03-2014, 12:58 AM   #14
Region: Arkansas
I understand I had to play with my idle when tuning my car, you'll figure it out. It isn't hard.
Full Bolt Ons
370rwhp 470rwtq
Old 12-03-2014, 05:25 AM   #15
fenixignition's Avatar
PaladinMicro.com
CliffyK's link.
2002 GT 5sp. 16x,xxx miles
Old 12-03-2014, 05:13 PM   #16
Billgluckman's Avatar
Does your speedometer work?
Billgluckman is offline   Reply With Quote
Old 12-05-2014, 12:58 AM   #17
samcrored's Avatar
it does work, not accurate without the tune (previous owner put a speed cal box , i saw it when i changed my shifter) so i dont know why it is not accurate but yeh
Old 12-05-2014, 11:25 AM   #18
Mfore33's Avatar
Have you tried the idle relearn?
I wanan do this soo bad Luna1994 General Mustang Discussion 3 10-15-2013 09:30 PM
soo many questions need serious help for my decision 98gtdriver 1996-2004 Mustang GT 9 05-28-2011 11:44 PM
Help!!!! I have $10,000 saved up and am tired of my friend bragging about his car!!!? finley General Mustang Discussion 5 03-30-2010 11:51 PM
Soo...I failed. matthews.stang The Bar 18 04-24-2007 10:14 PM
soo, what did I do last night? jimmy_beaner The Bar 28 12-05-2005 11:21 PM
04:37 AM
