98 gt running roughly - Mustang Evolution
Old 12-03-2014, 10:03 AM   #1
Faststallion98's Avatar
I have a 98 gt which recently started running very rough. There are no codes and the cel doesn't flash for a misfire but that is exactly what it feels like. It runs like this at idle and during exceleration but while cruising it's intermittent. I have read multiple posts on different sites but the issues are vast. I'm hoping to pinpoint this without wasting a lot of time checking every little thing. Any help would be greatly appreciated.
Faststallion98 is offline   Reply With Quote
Old 12-03-2014, 12:42 PM   #2
phillip433's Avatar
I would start diagnosing the problem with the ignition. Ignition wires, spark plugs. Etc.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 12-03-2014, 02:38 PM   #3
When is the last time it had a tune up?
Clean the MAF element
New filter or clean the K&N
Spark plugs
Motorcraft wires
If it hasn't been done in awhile you should do all that anyway and its not expensive.
Old 12-03-2014, 03:03 PM   #4
fenixignition's Avatar
check for vacuum leaks as well.
2002 GT 5sp. 16x,xxx miles
Old 12-03-2014, 03:25 PM   #5
Billgluckman's Avatar
Spark plugs
Motorcraft wires
Exactly, +fuel filter.
Billgluckman is offline   Reply With Quote
Old 12-03-2014, 04:08 PM   #6
I did a tune up last year I couldn't imagine it needing another one but being a mechanic nothing surprises me anymore
Old 12-03-2014, 04:57 PM   #7
Have you checked your coolant level? Any sign your losing some?
I'd look at the plugs at least, if you haven't already.
Actually, what have you checked/done so far?
Old 12-03-2014, 05:04 PM   #8
I haven't actually had a chance to look at the car and as far as the coolant the level it's good just did a flush 2 days ago
Old 12-03-2014, 06:16 PM   #9
Other than the tune up... the fuel filter and the crankshaft position sensor come to mind. Also the camshaft position sensor. I just sold a 98 and it was cutting out around 4k RPM. New crank sensor fixed it right up.
Old 12-03-2014, 06:43 PM   #10
fomoco4life's Avatar
COPs sometimes go without tripping codes as well, happened to a friend a while back, two boots were bad
Old 12-03-2014, 06:45 PM   #11
It could be anything. Look over the car first.
Old 12-03-2014, 06:49 PM   #12
Well I don't have to worry bout cop since I don't have that but the first chance I get ill go over the obvious things and look in spots where I was working and see if I didn't accidentally knocked something loose
Old 12-03-2014, 07:23 PM   #13
Beautiful thing about the 96-98 cars is that the coil packs almost never go bad and they use good old fashioned spark plug wires.
Old 12-03-2014, 07:58 PM   #14
Lol just noticed he's a 98, my buddy's was a 99
How much would it roughly cost to get a replacement key? sydeek General Mustang Discussion 2 12-18-2011 12:27 AM
Roughly how much would it cost to build your own new ford mustang gt coupe? chadburn General Mustang Discussion 2 03-20-2010 02:24 PM
Is anyone running the ZEX kit on their 6er? OMEGA7STARR Pre-2005 V6 Mustang 19 05-25-2004 05:41 PM
running from cops is bad....... mmmmkay? .:DarkEntity:. The Bar 10 10-11-2003 12:14 PM
It sucks not having a running car. : ( slow232 The Bar 0 07-15-2003 10:53 AM
04:53 PM
