tranny swap - Mustang Evolution
Old 12-03-2014, 05:56 PM   #1
tranny swap
i have a 2000 gt with an automatic transmission and i have been dieing to turn it into a 5 speed for some time know i cant find the transmission any where what are your thoughts on doing a tranny swap
steve_2000 is offline   Reply With Quote
Old 12-03-2014, 08:49 PM   #2
What kind of driving do you do mostly?
What are your plans for the car?
Does you automatic transmission still work properly?
Old 12-03-2014, 08:54 PM   #3
its my summer car and it works fine i plan on keeping the car and making it only for the track eventually
Old 12-03-2014, 08:55 PM   #4
If you like trannys, I got one I'll swap with you
Judge_dredd is offline   Reply With Quote
Old 12-03-2014, 08:58 PM   #5
What kind of track?
Drag strip or road course?
Old 12-04-2014, 03:34 AM   #6
Question?
Would a svt transmission be compatible with a v8 engine?
Sent from my SM-N910P using Mustang Evolution mobile app
jking97gt is offline   Reply With Quote
Old 12-04-2014, 05:28 AM   #7
There is no "SVT" transmission and different year Cobras used different transmissions. All were V8s.
You can get a brand new 3650 5 speed direct to your door for $1060 shipped from ebay. Personally my feelings on the topic are if you want to swap from one to the other... unless you have a stupid clean car with sentimental value, sell it and buy what you want.
If you are going to swap you will need:
-Trans
-Clutch
-Flywheel
-Cable/Quadrant/Adjuster
-Pedals
-Manual trans yoke for the driveshaft
-Shifter
-Crossmember/mount
-5 speed harness
-Auto computer tuned to turn off the auto functions
Figure the swap will run you $2k to do it correctly. Which is why I say sell the car and get a 5 spd car. Its not that the swap is exactly hard... its not worth it $$ wise.
Old 12-04-2014, 05:48 AM   #8
drag strip
Old 12-04-2014, 06:03 AM   #9
Then stay with the auto, you'll be faster. Look up "j-mod tccoa" on youtube and it'll show you how to do one. Basically you're installing a "shift kit" in the trans which will also increase longevity and its only $60 plus the cost of fluid.
Old 12-04-2014, 06:06 AM   #10
-Trans
-Clutch
-Flywheel
-Pedals
-Shifter
-Crossmember/mount
-5 speed harness
I have a 5 speed already . I have 97 gt 5 speed (t-45) . I was asking cause recently my transmission gave out on me . And people keep telling me its the clutch but if itss the clutch then why wont the car stall when its in 1st gear and the clutch has been released. And im thinking the tranny isnt good anyone . Im not sure if the transmission flush i did that cause it . But i seen a transmission from svt engine cheap on ebay.
Old 12-04-2014, 06:28 AM   #11
The 96-98 Cobras also use a T-45, but you don't want it because the crossmember mounts in a different location than the GT. Your best bet is to get a rebuilt T-45 from The T45 Source - Proven, reliable T45 Transmissions
Look them up, call and talk to Zak and he'll go over your options with you.
Although if the car does not stall in 1st gear that is probably the trans if you can feel the clutch grabbing unless something with the clutch physically broke. You'd have to pull the trans and get in there and see wth is up regardless and at that point you might as well get a new flywheel/clutch anyway while the trans is out. Upgrade to an 11" flywheel and clutch setup too if you get a new clutch. There is nothing else you need to do besides get an 11" flywheel and 01-04 11" clutch to do the upgrade there.
96-98 transmissions are notorious for going out anyway. Bad 5/R fork and the blocker fall apart after awhile. In 99 the were fixed with a re-designed fork and carbon fiber blocker rings and are much better.
Old 12-04-2014, 08:30 AM   #12
so what should i look up in youtube?
Old 12-04-2014, 09:38 AM   #13
Its in quotes in the previous posts. Its a mod called the "j-mod". Makes your trans shift much faster/harder and improves overall life of the unit as well.
Old 12-05-2014, 11:28 AM   #14
Mfore33's Avatar
I've got a 2000 gt auto with 201,000 miles on it. I just did the 4 th trans fluid and filter change and still a clean pan. Would the j mod be worth the trouble with this many miles?
Old 12-05-2014, 11:31 AM   #15
Sure it couldn't hurt it if that's what you are asking. It'll make the car feel like a whole new animal that's for sure.
Auto tranny VS. Manual tranny x2bittz Classic Mustangs 15 06-29-2013 07:07 PM
v6 tranny to a v8 tranny 97V6stangct Pre-2005 V6 Mustang 4 02-04-2012 12:42 PM
98 mustang engin/tranny swap Mustangbobby General Mustang Discussion 0 04-17-2008 07:34 PM
98 Engine/tranny swap Mustangbobby Pre-2005 V6 Mustang 0 04-17-2008 06:51 PM
Tranny Swap 1234 1996-2004 Mustang GT 20 03-07-2007 08:12 PM
04:47 PM
