Cobra driveshaft for t56 - Mustang Evolution
Old 12-07-2014, 02:01 PM   #1
phillip433's Avatar
If I use a cobra driveshaft in for my t56 swap. Do I need to change the flange or anything for my rearend? Also. The cobra crossmember, is there a rubber piece that goes between the tranny and the crossmember ?
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 12-07-2014, 03:14 PM   #2
Mile high JDF's Avatar
There's two ways you can do that, you can buy a Cobra flange for your differential or you can buy a hybrid u-joint and transfer your GT flange from the GT driveshaft to your Cobra driveshaft
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-07-2014, 04:32 PM   #3
The IRS uses a different pinion flange than the SRA so yeah, you need to swap over the SRA flange from your DS. For the yoke, you need the 27 tooth yoke for a T56. However you wind up with the 27 tooth yoke and the correct pinion flange for your rear, that is what you need.
For the crossmember, that rubber piece is the trans mount so yeah... thats needed.
Old 12-07-2014, 04:32 PM   #4
Old 12-07-2014, 05:45 PM   #5
phillip433's Avatar
So I don't need a steeda spacer for the DS? And I can't find the transmission mount anywhere. Late model has one but it's not for 99-04. I have a cobra crossmember I just need to get the mount for a t56
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
02 mustang gt>forged cobra swap,t56, $10,000 SimplyOrange Mustangs for Sale and Wanted 44 10-08-2008 02:19 PM
T56 for sale, sounds like a great price PureVenom The Bar 2 06-15-2005 09:14 PM
11:38 PM
