EGR Valve code - Mustang Evolution
Old 12-07-2014, 02:46 PM   #1
HighlyBored's Avatar
EGR Valve code
Been putting off getting my car inspected for longer than I'd like to admit because it's been throwing a code for the EGR valve since I bought it a year ago. I bought the car knowing it had that code because
1. Faulty EGR valve isn't hurting anything
2. A new valve isn't expensive
3. Takes less than 5 minutes to replace it
So, the weekend after I bought it I replaced the valve, but the code persisted. I took it to advanced auto and had them clear the code and it popped back up after 100 or so miles once it reset itself. So here I am, a year later procrastinating still.
The only things that I'm aware that it could possibly be is a pinhole leak in one of the hoses, or maybe a carbon build up somewhere. Anyone have a similar issue or any input?
HighlyBored is offline   Reply With Quote
Old 12-07-2014, 05:33 PM   #2
Speed_Mister's Avatar
Region: Arkansas
I just delete my EGR on all my mustangs.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-07-2014, 09:12 PM   #3
There are several possibilities when an EGR code is displayed... Engine coolant temperature sensor, Throttle Position Sensor, Mass Airflow Sensor.
It would be helpful if you could give us the exact code so that we can possibly narrow this down a bit.
Old 12-07-2014, 09:15 PM   #4
It's EGR Insufficient Flow. Did a bit of research and apparently it's probably carbon build up. I'm going to try to clean up the TB and whatnot this weekend if I can.
Sent from my SM-G900T using Mustang Evolution mobile app
Old 12-07-2014, 09:43 PM   #5
Yeah, you must have P0401. Take it apart and clean the EGR ports. If you still get the code, the next thing to check is the DPFE sensor.
Old 12-15-2014, 03:08 PM   #6
Cleaned out the throttle body this weekend, code popped back up again. I'm going to look into the DPFE sensor next, if that doesn't fix it I'm scrapping the car.
Jk. But really after that I'm out of ideas.
EGR VALVE Eeyore General Mustang Discussion 14 04-16-2009 08:51 AM
Exhaust leak/ticking. Possible EGR Valve? amowry01V6 Pre-2005 V6 Mustang 0 09-10-2008 07:25 AM
10:36 PM
