Questionable spring installation - Mustang Evolution
Old 12-08-2014, 05:43 AM   #1
bigmac3's Avatar
I just had a set of lowering springs installed on my '02. All seemed fine. I was going to do some work under the front end this weekend and discovered that I have two different sized springs on the front end. Apparently they screwed up when installing them. Which should be on the front end, the larger or smaller ones? I have a large on the left front and a small on the right front. I also now have a scraping sound coming from the left front when the wheel rotates. I am taking the car back to the shop today but was just wondering.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 12-08-2014, 08:29 AM   #2
Mile high JDF's Avatar
Pictures would be great if possible. It sounds like they large one would be the one meant for the rear. Did it come to a tight coil on one end?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-08-2014, 09:25 AM   #3
bigmac3's Avatar
Couldn't see the ends. I would think the larger would go in the front due to engine weight. I'll see when I go to the shop. When it's all said and done, It may just have been an illusion as there is more of a noticeable difference in length than I had remembered.
Frank
Old 12-08-2014, 09:32 AM   #4
Ok. The left side springs in that picture go in the rear, right side is front
Old 12-08-2014, 09:38 AM   #5
bigmac3's Avatar
That's what I would have thought. When I looked at mine, the coils on the right front looked thinner, hence the left ones in the photo.
Frank
Old 12-09-2014, 12:17 PM   #6
bigmac3's Avatar
OK, I'm standing here with egg on my face. I took the car back to the shop and the guys couldn't have been nicer. They put it on the lift and gave me every benefit of the doubt. When I got under there, I found that the springs were indeed identical and properly installed. The way the LCA is designed, you can't install them wrong. I'm certainly glad that I have this shop to depend on. The scraping noise that I had heard was simply the backing plate slightly bent and rubbing the rotor. Quick fix and all is well. I did discover that I have a minor oil leak. Not sure if it's from the pan or the rear main. I'll have them fix both when it gets worse. Meanwhile I'll keep my eyes open for a 4V motor. I saw a Lincoln MkVIII for sale. Anyone have experience with swapping out one of them?
Frank
Old 12-09-2014, 12:29 PM   #7
Well that's some good news! The 4V swap isn't terrible, I believe we had a write-up on this forum a while back. The biggest difference will be the wiring for the coils are different on a 4V motor
Questionable Mod silvrbullet2012 General Mustang Discussion 12 01-23-2014 05:47 PM
Spring installation Top stang 1996-2004 Mustang GT 6 04-27-2013 11:34 AM
stock spring spring Scut95 1979-1995 Mustang GT 2 09-15-2005 04:11 PM
Saleen Bumpers Installation Assistance or Guidance KrazyPony Mustang Audio & Video 5 09-23-2003 12:08 PM
'98 MAC Underdrive Pully Kit Installation Mustang414 Pre-2005 V6 Mustang 2 08-20-2003 12:14 PM
10:29 AM
