Clutch Question - Mustang Evolution
Old 12-08-2014, 06:35 AM   #1
v8pony's Avatar
Clutch Question
So recently my clutch has been making all sorts of noise, when its cold outside, and the clutch is not touched, it makes almost a swirling type noise, when I go to the floor it makes an even louder squeakish noise, and when the car gets up to temp there is no noise at all when you keep your foot off the clutch, still makes some noise when pressed to the floor but not nearly as much when cold..now I'm assuming this is going to be my throw out bearing, but when it warms up it shifts like butter and the clutch grabs great. My question is could this maybe just be an adjustment issue? Or is this a common symptom when the TOB starts to go out? Just wondering if I should hop on replacing the entre clutch asap, or if I get some more time out of it by getting maybe an adjuster/quadrant, and new cable possibly, funds are just a bit tight with Xmas around the corner..thanks guys
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-08-2014, 07:54 AM   #2
fenixignition's Avatar
were you the one with the napa bearing? Where youlive and what temp ranges are you in? here in FL (clearwater) were hittin high 50s in the morning and a high of 70, so cold, mine squeaks until i press the clutch. if it squeaks when you press the clutch pedal, then it sounds like throwout bearing. Maybe not on its way out, but probably some wear. I've always been told that the cause is listed as "not yet up to operating temperature." so all i got from that was "tr3650 is noisy if cold."
Mine makes a noise, somewhere between "grinding" and "rattling" in 5th gear if the transmission isnt warm yet. I guess its a similar bearing issue, where it needs to warm up.
2002 GT 5sp. 16x,xxx miles
Old 12-08-2014, 08:15 AM   #3
If it's making noise and your not touching the clutch it could be pilot bearing
Old 12-08-2014, 09:02 AM   #4
Easy to see if its the pilot. Push the clutch in and if it starts to make noise with the clutch fully disengaged then its likely the pilot.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 12-08-2014, 09:22 AM   #5
figures, i had it backwards. neutral, running, foot off the pedal, and squeaking, that would be tob then?
Old 12-08-2014, 09:38 AM   #6
Yes. The pilot engages when the input shaft of the trans stops moving which happens when you push in the clutch pedal.
Old 12-08-2014, 02:24 PM   #7
Billgluckman's Avatar
I believe you're thinking about me with the napa bearing.
Billgluckman is offline   Reply With Quote
Clutch adjuster, clutch, or tranny Elcobrachingom SVT Mustang 3 09-05-2012 06:32 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
Dual Clutch Vs Single Clutch 504 Stang Rida 1996-2004 Mustang GT 7 11-29-2011 07:22 PM
10:30 AM
