heater blend door - Mustang Evolution
Old 12-09-2014, 11:38 AM   #1
fenixignition's Avatar
heater blend door
Not sure if its actually the heater blend door, it may just be a mustang thing. I was surprised when i realized the floors get hot from the cats. also, dont have any other ones to compare it to.
If its about, 70 to 75 degrees out, the air outside is nice, but after the engine warms up, forget about any of that cool air making it through the vents. when its 60 out, even then, its much warmer through the vents. it only seems to be when its really cold out or before the engine gets hot that it almost feels like the ac is running. If its mid day and the sun it out, its even worse (duh, sun is hot)
so im wondering if this is familiar to everyone, and its just a big engine making a lot of heat and i should shut up and just turn my ac on,
or does it sound like my heater blend door isnt closing all the way?
temp is set as low as it can go. The only other thing i was considering, because i do not want to remove my dash, is a temporary heater core bypass, and see if it still gets hot without coolant running to the heater core.
any thoughts/experiences?
2002 GT 5sp. 16x,xxx miles
Old 12-09-2014, 01:35 PM   #2
My car also gets very warm in the summer time but it is dark blue as opposed to your white car. I've never noticed any excessive heat coming from any of the vents though.
When I replaced the heater core, the blend doors had a strip of foam around them as a sort of weatherstripping... If I remember correctly.
Possibly, that foam has deteriorated and is letting some of the hot air escape even when that door is fully closed (Temperature knob set to full cold position).
When you turn on the A/C, does it get nice and cold like it is supposed to?
Old 12-09-2014, 01:46 PM   #3
yea ac works just fine (for how old the compressor and all that is) but that actually sounds about right, maybe the foam is gone.
Old 12-10-2014, 08:54 PM   #4
phillip433's Avatar
I can relate to this. I thought it was just me but I feel as if the engine gets really hot,warmer air comes through the vents compared to when I first start up my car when the a/c is on full blast on lowest temp. I think it's just that the engine gets really hot and our a/c system isn't good enough to keep up with the heat the engine gives out.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Full synthetic, synthetic blend, or regular LeahMaurine 2005-2010 V6 Mustang 10 01-20-2015 07:34 PM
Actuator door blend motor jnieto7 Mustang DIY and Technical 2 09-12-2014 11:55 AM
Full synthetic or blend dacm99 2011-2014 V6 Mustang 32 06-08-2014 12:38 AM
03 gt air blend door? 03GT88 1996-2004 Mustang GT 8 07-01-2013 10:06 PM
My heater scuks in fumes when I turn on the heater jaynez31 Pre-2005 V6 Mustang 3 02-08-2006 06:44 PM
02:58 PM
