Fuel Tank Filler Pipe - Mustang Evolution
Old 12-09-2014, 06:25 PM   #1
from what I find online I think I need to replace my Fuel Tank Filler Pipe. I see you can access it through the trunk. is this as simple as a disconnect and reconnect or is there more to it?
Hello is offline   Reply With Quote
Old 12-09-2014, 07:40 PM   #2
XSlashDashX's Avatar
What's the problem? Could be a simple gasket that goes between the pipe and gas tank.
Old 12-09-2014, 08:12 PM   #3
JCOB72's Avatar
It's not as simple as it sounds. I had to replace mine and it was a PITA.
JCOB72 is offline   Reply With Quote
Old 12-10-2014, 12:18 AM   #4
Speed_Mister's Avatar
Region: Arkansas
I would change fuel filter easy disconnect, if that doesn't fix the issue, your almost better off upgrading you fuel pump. I bought my aviator 310lph pump for 50 bucks on eBay with the fuel pump filter that snaps in at the bottom which is what you are referring to I believe. It's not hard undo straps that hold gas tank, pull out pipe to gas filler, disconnect the wire harness to fuel pump unbolt 8 bolts pull assembly out of tank, unbolt assembly and pull out your fuel pump with the filter snapped in at bottom of pump.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-10-2014, 05:57 AM   #5
I think it has to do with the vented tube. When I fuel my car it does not want to go down the tube normally. Have to barely pull the trigger and just barely have the gas gun in the opening for it to go in.
Old 12-11-2014, 05:34 AM   #6
fenixignition's Avatar
I'm a member of that club.
do our cars have a charcoal cannister? idk if thats just newer cars or what. idk if its part of the filler neck. but I know on my old car its caused by trying to add more gas after the click. it soaks the charcoal cannister and degrades it, and air doesnt flow as well as it should, causing it to overfill at the neck. kind of like pouring used oil into a bottle using a funnel and not lifting the funnel off the bottle while you pour.
2002 GT 5sp. 16x,xxx miles
Old 12-11-2014, 05:42 AM   #7
do our cars have a charcoal cannister? .
yah but its in the drivers side wheel well
Fuel Neck Filler??? Mustang1804 1996-2004 Mustang GT 6 12-21-2011 03:56 AM
fuel tank filler neck seal advice. HaulinTwinz 1979-1995 Mustang GT 11 03-26-2011 10:01 PM
Big Problem with the gas tank/filler neck/fuel etc runvsofthisbull Pre-2005 V6 Mustang 4 08-16-2010 08:30 PM
Fuel filler tube, grommet? Otlaw80 Pre-2005 V6 Mustang 4 05-12-2009 11:41 AM
Fuel Tank/filler neck Scut95 1979-1995 Mustang GT 8 11-26-2008 01:15 PM
11:35 AM
