SR 70MM throttle body and SR upper intake plenum - Mustang Evolution
Old 12-11-2014, 08:43 AM   #1
Jay180's Avatar
I'm thinking if getting the throttle body first then the intake. Any suggestions on what to get first or instead?
Jay180 is offline   Reply With Quote
Old 12-11-2014, 09:08 AM   #2
fenixignition's Avatar
plenum first. throttle body, i hear most say that you wont notice anything. i didnt notice a difference going from 75mm to stock. but th plenum is the chokehold at high rpm. tb is best for boosted. what do you mean by intake? intake is from the filter to the manifold.
2002 GT 5sp. 16x,xxx miles
Old 12-11-2014, 09:24 AM   #3
Jay180's Avatar
When I said intake I was referring to the plenum
Old 12-11-2014, 09:31 AM   #4
yea wouldnt bother with the tb unless boosting, then youl need it. i dont know for sure how noticeable the new plenum would be, but at higher rpm, it should allow the full amount of air into the engine without much restriction, if any at all.
Old 12-11-2014, 11:16 AM   #5
Jay180's Avatar
Thanks I'm going to get the plenum then get a spacer with the throttle body together
Old 12-11-2014, 11:20 AM   #6
might wanna get more feedback about spacers too. Last i heard, they were a waste of money, but i dont remember the circumstances.
Old 12-15-2014, 06:38 PM   #7
Get the 75mm don't mess with a 70mm
04sonic is offline   Reply With Quote
Old 12-15-2014, 07:48 PM   #8
Skip the SR as well, get the Trick Flow setup. $279 for the plenum and the 75mm TB on Summit or Jegs. Proven numbers, USA made vs Chinese sweat shop children, and quality is dead on.
Old 12-15-2014, 11:55 PM   #9
Jay180's Avatar
Aren't the 75 mm for more modified cars? All I have is a CAI and exhaust
Old 12-16-2014, 09:24 AM   #10
No, 75mm is the one you want regardless. CAI isn't doing anything for you. Exhaust will a little but the factory mid pipe needs to go if you want anything appreciable as far as gains.
Pretty much you want:
-4.10 Gears
-Shifter
-Midpipe/Catback
-MPT Tune
-Suspenson Suspension Suspension
Anything else before a power adder or engine work is just wasting money or ricing your car.
Old 12-16-2014, 11:15 AM   #11
Jay180's Avatar
I see you always tell people to do their suspension, which do you recommend?
Old 12-16-2014, 01:37 PM   #12
Basic setup for beginners.
-Max Motorsports CC plates
-SR springs
-Tokico Illumina Shocks/struts
-Steeda Lower Control arms
-Leave the stock Upper Control arms alone
-Steeda or Spintech (ground clearance) subframes
That'll get you launching decently but until you do a full rear suspension overhaul as in a torque arm/panhard bar setup for the solid axle or swap in a IRS with the Full Tilt Boogie Racing bushing kit it won't be really correct.
Old 12-16-2014, 11:03 PM   #13
Save money buy the summit racing plenum and TB trick flow makes them for them.
Old 12-17-2014, 12:53 AM   #14
Jay180's Avatar
Is the suspension in that order, does it matter what I get first? And I'll look into the trick flow I've been seeing that a lot
Old 12-17-2014, 11:35 AM   #15
Subframes and lower control arms first. Then you do springs/shocks/struts/cc plates all at once. Then drive gingerly to an alignment shop and get a good alignment and you are good. If you are going lower than 1.5" get a bumpsteer kit too. I don't see the need to go lower than that personally, not for street driving.
After that I'd look into a good set of wheels and tires. When I say good set I don't mean Sumis. Continental for all seasons, BFG for a good budget summer tire or Mickey Thompson Street Comps for a bit pricier/best summer tire.
70mm SR TB/plenum vs. 78mm BBK throttle intake StangerBanger04 1996-2004 Mustang GT 31 04-20-2013 10:54 AM
70mm Throttle Body/Plenum or SCT Tuner? StangerBanger04 1996-2004 Mustang GT 13 09-13-2012 09:11 PM
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Stock 2002 GT Throttle Body and Plenum...End today Junior2561 Mustang Parts for Sale and Wanted 0 02-23-2004 07:08 AM
01:57 PM
