Clunking when downshifting - Mustang Evolution
Old 12-12-2014, 02:07 PM   #1
Panther140's Avatar
So when I drive my car, it doesn't really make any alarming noises. Mustangs are pretty noisy cars with their fair share of driveline slop, but Im not sure what all is considered normal.
When I downshift to second, I get a noticeable whining noise, which is normal for a 4.6 engine. But when I downshift into first, I get a pretty sloppy clunking noise that doesn't stop until I disengage the clutch.
Is there anything I should look out for? I am going to change the diff oil as soon as I can. Do you guys recommend a certain gear lube for the rear end on these? Is there a common problem that causes this noise?
Panther140 is offline   Reply With Quote
Old 12-12-2014, 03:45 PM   #2
Panther140's Avatar
Found out what my clunking noise was.
Pulled the dip stick
Old 12-13-2014, 08:39 AM   #3
fenixignition's Avatar
Ouch. Well as far as rear diff, mobil1. Its expensive. But get 3 full quarts in.without spilling and you should be okay.
Sent from my LG-D800 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
3 to 2 downshifting issues jayg20769 General Mustang Discussion 1 08-11-2014 07:27 AM
downshifting question FriedChicken General Car Discussion 5 12-04-2013 03:18 PM
Difference between downshifting techniques? iphonemaster93 Pre-2005 V6 Mustang 25 09-08-2012 09:57 AM
Proper way of downshifting? iphonemaster93 Pre-2005 V6 Mustang 23 01-18-2012 08:39 PM
downshifting rumble...clutch problem?? maximus 1996-2004 Mustang GT 21 05-29-2007 05:27 PM
05:32 AM
