Couple Of Tuning Questions Please - Mustang Evolution
Old 12-13-2014, 10:07 AM   #1
I am going up to the shop this afternoon and tune my 04 GT after being in my friends Speed Shop having performance and suspension modifications performed. The tank is full of Shell 93% gasoline. First does the engine need to be warmed up, the car is in the shop and I had a little heat on but it was 23 degrees here this morning and probably is 60+ in the shop.
Secondly, engine running or off while down loading the tuneup, I know it won't make any difference but I am going to use the Race tune and I assume battery fully charged, don't use any electrical accessories ie. windows, door locks, stereo/radio.
If you see this thread and would not mind sharing your expertise I will appreciate it.
Thanks
Landspeedracer is offline   Reply With Quote
Old 12-13-2014, 10:16 AM   #2
Laquisha's Avatar
Turn off ac and every thing. Make sure the car is off. Plug the handheld into your car and then select tune and press ok. U then turn the key to the right all the way but don't start the car,. Then let it load and press ok when done then turn the car off. It will direct U while u do it. I did it last week. Was pretty easy
Naturally Aspirated Is Lyfe
Old 12-13-2014, 10:44 AM   #3
Thank you very much, heading up to the shop now!
A couple changes over the past couple months RHuckster 2005-2010 Mustang GT 6 02-18-2008 08:50 AM
Couple questions for ya Sassa Massa 1979-1995 Mustang GT 4 08-15-2006 05:20 PM
I have a couple 5.0 swap questions colinsv6stang 1979-1995 Mustang GT 5 04-28-2006 12:18 PM
Couple of tire questions cterie Mustang Wheels & Tires 11 03-08-2006 08:35 AM
A couple of questions to kick around mohrnormal The Bar 3 02-09-2005 08:06 PM
11:30 AM
