Fuel Pressure question - Mustang Evolution
Old 12-14-2014, 11:20 AM   #1
xfree143's Avatar
Anyone know what fuel pressure I should have with a pro charger on my 99 GT?
xfree143 is offline   Reply With Quote
Old 12-15-2014, 05:48 PM   #2
Panther140's Avatar
Wouldn't it depend on your tune? Id imagine you could run it at 35 PSI and be fine if you tune the ECU for that, but you would have to make sure that your fuel pump can maintain 35PSI at maximum duty cycle. Once again though, I am talking out of my ***!
Panther140 is offline   Reply With Quote
Old 12-15-2014, 07:32 PM   #3
xfree143's Avatar
I'm running 40psi but it is randomly loosing pressure to 6lbs. I have to shut the car down then start it again and it's fine. It may go a day or two before it does it again. It's driving me nuts, I have changed the fuel filter and the fuel pressure sensor at the rail but it's still doing it.
Old 12-15-2014, 07:40 PM   #4
Panther140's Avatar
When it does that, leave the key on and test points with a voltmeter. Maybe even with the engine running. I would check before and after the relay and before and after the fuel pressure regulator. Also test right before the fuel pump. Maybe check the fuse in the box. Ive had light bulbs and fuses "go bad" but still sometimes work for no reason. That might tell you a lot. That's what I would do. Otherwise you can get your parts shotgun out and start replacing **** lol.
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
fuel pressure question Jar72 1979-1995 Mustang GT 1 02-02-2014 10:56 AM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
Fuel pressure guage questions eagle05 1979-1995 Mustang GT 4 10-25-2006 04:47 AM
No schrader valve on 05s for wet N2O or Fuel Pressure guage justin00stang 1996-2004 Mustang GT 1 11-17-2005 08:08 AM
04:52 AM
