Intake vs. Cams - Mustang Evolution
Old 12-16-2014, 11:26 PM   #1
Intake vs. Cams
I was wondering what would be better to get pullies and intake manifold or cams? I already have the 75mm TB and plenum headers and exhaust
04sonic is offline   Reply With Quote
Old 12-16-2014, 11:35 PM   #2
Definitely cams and a dyno tune!
There's no real need to change the intake manifold.
Old 12-17-2014, 01:40 AM   #3
Raeko's Avatar
Definitely cams . If you can afford it id also say that it would also be a good time to port the heads as well to gain the most power
Raeko is offline   Reply With Quote
Old 12-17-2014, 12:35 PM   #4
Panther140's Avatar
cams for sure man. Cams and some borla ataks. You will drive thousands of miles a week just to listen to that sum***** purr.
Panther140 is offline   Reply With Quote
Old 12-17-2014, 12:58 PM   #5
Well the cams are going to be a lot more expensive. Because if you want to do it right you will need the cams, cam gears, new valve springs at minimum. And if you need them installed at a shop get ready to pay $500+ just for that. Also need to make sure the rest of your car is up to par. With bigger cams you lose a bit of bottom end so you need different gears, or a higher stall if you are an auto.
But like Straybullitt said, no real need to change the intake manifold.
Old 12-17-2014, 06:14 PM   #6
The PI intake supports 600+ to the wheels, 0 reason to change it unless you are worrying about nitrous puddling.
Cams are going to be about $1500 having a shop do it. You can buy a complete used Vortech in really good shape for that and be +100whp and retain stock gas mileage and street manners if you keep your foot out of it.
Obviously you'll still need to source a fuel pump/injectors but that's not all that much more if you are already at $1500 for an extra 100whp over a cammed 2V.
Tune is required regardless so that's a wash.
Old 12-18-2014, 09:36 AM   #7
Better intake will bring more hp though won't it?
Old 12-18-2014, 09:59 AM   #8
An intake won't add enough power, over your current intake setup, to justify the cost. The gain would likely be around 10 hp. You've already fixed the biggest problem with the factory intake which is the plenum.
Old 12-18-2014, 10:12 AM   #9
I heard if you do the intake and cams you can gain around 50-60 hp. I'm in college so was gonna start with intake and pullies then go for cams next year after I save up.
Old 12-18-2014, 10:27 AM   #10
Well just do the pulleys then. The plastic PI intake is really quite good! Unless you are dead-set on getting an aluminum intake, mostly for cosmetic reasons, there is no need to replace the stock intake. Save that money for mods that will net you some real gains!
Old 12-18-2014, 10:29 AM   #11
What else is a good mod that isn't a lot I have headers x pipe cat back TB plenum and CI
Old 12-18-2014, 10:33 AM   #12
Does your car have a tune?
Your car has 21 lb injectors which make it run rich at wide open throttle. A tune can really help with that.
Old 12-18-2014, 10:35 AM   #13
I was thinks of a dyno tune but then thought it would be pointless if I have to get one for cams. Should I just get a sct?
Old 12-18-2014, 10:45 AM   #14
I'd get a tuner and a few tunes instead of the intake. Yes you will have to get it re-tuned for the cams but it will make a noticeable difference.
Old 12-18-2014, 10:47 AM   #15
Okay thanks for all the suggestions!
Old 12-18-2014, 12:20 PM   #16
And make sure your tuner will tune for cams if you are thinking of getting them in the future. MPT will, Bama/Steeda will not. Too many ppl find out the hard way that their canned tuner is just that. A canned tuner.
Old 12-18-2014, 12:30 PM   #17
I heard good on Diablo anyone know if that does?
Old 12-18-2014, 12:46 PM   #18
Not as good a job as a SCT Handheld.
Old 12-18-2014, 01:17 PM   #19
audioAl's Avatar
SCT 3015 by Motorvation EFI
SCT rules!
Name:	tn_SCT 3015 002.JPG
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 12-18-2014, 02:24 PM   #20
That will work with cams when I get them?
96-98 cobra intake cams 03Graymach 1996-2004 Mustang GT 19 11-18-2014 03:00 PM
Intake Manifold and CAms for 2000 gt exceso 1996-2004 Mustang GT 14 09-23-2013 04:56 PM
Cams and intake manifold MustangGT02 1996-2004 Mustang GT 6 05-21-2013 08:08 PM
Heads, Cams, Intake 2kslvrgt 1996-2004 Mustang GT 19 03-13-2009 10:33 PM
intake porting and powdercoating intake(RGR) 232SCstang Pre-2005 V6 Mustang 7 01-11-2004 08:41 AM
10:37 PM
