Changing gears - Mustang Evolution
Old 12-18-2014, 11:46 AM   #1
Jay180's Avatar
Changing gears
Every time I change gears it's a little hard to put the shifter into the right gear. It needs to forced but not too much. Is this normal? I just changed my clutch, could it be my differential?
Jay180 is offline   Reply With Quote
Old 12-18-2014, 03:53 PM   #2
Panther140's Avatar
Your differential is in the rear axle and doesn't really have anything to do with your transmission. What you might have going wrong is the synchros. They align the gears so that they can mesh smoothly when you shift.
If you do what is called double clutching, it should help preserve the synchros and gears as well.
Double clutching is as follows:
1-push in the clutch
2-take the shifter and start moving it toward the next gear, but don't go all the way
3-release the clutch pedal when the stick is inbetween gears (neutral)
4-Push the clutch pedal in, and put move it into the next gear
What this does is let the synchro start spin before it normally would, and it does so at the correct speed. It makes things way more easy on the transmission. I do it when I am just daily driving because I feel like im saving on the trans when I do it.
If you are only feeling a minor resistance when putting it in gear, its probably normal and you might just be over thinking it. You shouldn't have to really Muscle it in tho. It should be relatively effortless, just with a noticeable engagement
Panther140 is offline   Reply With Quote
Old 12-18-2014, 08:38 PM   #3
Jay180's Avatar
Oh alright I'll practice double clutching. It's my first manual car so I don't know what it should feel like
Old 12-19-2014, 06:56 AM   #4
fenixignition's Avatar
What kind of fluid you got in there? Short shifter? How many miles?
Sent from my GT-P3113 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 12-21-2014, 03:58 PM   #5
Jay180's Avatar
To be honest I don't know about my fluid I tried looking for my transmission fluid stick but realize I don't have one cause I'm manual and it has 146k and I have the stock factory shifter
Old 12-22-2014, 07:28 PM   #6
Your first order of business should be a fluid drain/fill and a MGW shifter. Especially if you have a 01-04 car.
Old 12-22-2014, 08:17 PM   #7
Changing gears
Step 1: buy MGW shifter
Step 2: go buy 4 quarts of Pennzoil Synchromesh
Step 3: pull shifter and drain tranny oil.
Step 4. Put drain plug in, and fill up tranny with 3.2 quarts fluid.
Step 5: Install MGW shifter
Step 6: go bang some gears like a bawssss
Old 12-22-2014, 09:24 PM   #8
Panther140's Avatar
synchromesh for sure. emphasis on synchromesh.
Old 12-22-2014, 09:26 PM   #9
Pennzoil synchromesh (or GM Synchromesh, same stuff) is the ONLY product that should go in these manual transmissions
Old 12-23-2014, 02:29 AM   #10
I gotta try that synchomesh
Sent from my 0PCV1 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 12-23-2014, 09:16 AM   #11
phillip433's Avatar
What about a t56. How many qts should a t56 hold.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 12-23-2014, 01:33 PM   #12
Jay180's Avatar
What kind of mgw shifter?
Old 12-23-2014, 07:46 PM   #13
The kind for your transmission.
Old 12-24-2014, 07:48 AM   #14
parkerz28's Avatar
Have to agree change your fluid with the correct flavor and shifter... I have the pro 5.0 but whatever you choose it will be night and day
Sent from the back seat
parkerz28 is offline   Reply With Quote
Old 12-24-2014, 07:54 AM   #15
parkerz28's Avatar
I actually changed clutch, throw out bearing, pilot bearing, clutch fork... And fluid and used the stock shifter for 300 miles before I changed to the 5.0... Just with the stock shifter it was like butter switching gears... The 5.0
Is a little notchy feeling but like the positive shift it gives... Mine is a 2004 with 75,000 when I changed all that 5 months ago
Old 12-24-2014, 08:21 AM   #16
WJL
LOL Double Clutching what's he driving a B Model Mack, if you didn't have this problem prior to replacing the clutch that's what i would be looking at, this can happen if the clutch is not completely disengaging. Did you replace the clutch yourself or was it done by a shop? if shop take it back and tell them it wasn't like this before. I wouldn't go buy a short throw shifter until you resolve the issue its not going to fix the problem.
JMAO.
WJL is offline   Reply With Quote
Old 12-24-2014, 09:17 AM   #17
The 5.0 is ok, the straight up shifter handle is ****ing retarded tho, most ppl swap out with an angled handle so they aren't leaning way forward for 3rd and smashing their fists into the radio on a hard shift. The Tri Ax is good too but noisy, the MGW is the best one.
Old 12-27-2014, 12:05 PM   #18
Jay180's Avatar
I had this problem before fixing my clutch. I thought changing my clutch would solve the issue but it didn't. I go it done at a shop
Will a tuner and changing out gears effect smog? AznGuyNamedEd 2011-2014 V6 Mustang 8 06-18-2014 09:51 PM
Trouble changing gears Crowned1 Pre-2005 V6 Mustang 3 01-28-2013 01:32 PM
Changing gears and differential. What do I need? Polar Bear 1996-2004 Mustang GT 16 01-07-2013 04:25 AM
Changing the gears 06 mustang Pattyboy 2005-2010 Mustang GT 8 09-17-2012 10:16 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
10:26 AM
