Burning oil - Mustang Evolution
Old 12-20-2014, 03:46 PM   #1
Boosted_3v's Avatar
Burning oil
My buddy has a 02 GT and is burning oil like crazy, will a breather system help him out?
Boosted_3v is offline   Reply With Quote
Old 12-20-2014, 04:13 PM   #2
If the stock one has failed then maybe. But valve guides or rings or a leak is what makes oil leave.
sledge42hammer is offline   Reply With Quote
Old 12-20-2014, 05:11 PM   #3
ultrawhiteSN95's Avatar
I was thinking the same thing as far the rings
When your buddy is driving his car and just say he wants to stop and talk to someone while his car is still running for like 5 or 10 minutes , then he drives off does the car smoke alot from running parked for 10 minutes? If it does im thinking its his rings , or maybe it could be his pvc valve is bad , if the pvc valve is bad it can cause oil leaks and build up and that could cause it to smoke too
1998 GT, Edelbrock Victor Jr. Ford 4.6L SOHC, Edelbrock Fuel Rails, 1999 Gt Engine w/ PI Heads,Accufab 70mm TB & Plenum,Fuel Pressure Regulator 515 Series Inline Return Style, 25-90 psi, Underdrive Pulleys,MSD ignition coils ,4.10 gears,Diablo Sport Predator Tuner
ultrawhiteSN95 is offline   Reply With Quote
Old 12-20-2014, 10:31 PM   #4
Boosted_3v's Avatar
Hmmm let me ask him because he said he just got the motor rebuilt so maybe the PVC is just clogged up lol
Old 12-20-2014, 10:36 PM   #5
If it's just rebuilt it may not have seated rings yet or hones out too much which will cause blow by
Old 12-20-2014, 11:05 PM   #6
Boosted_3v's Avatar
Very true
Going to check PVC thanks for the advice
Old 12-21-2014, 12:29 PM   #7
Boosted_3v's Avatar
Name:	ImageUploadedByMustang Evolution1419190110.547035.jpg
Found this on the said of his oil cap and looks like it's in the motor too any way to clean this crap out
Old 12-21-2014, 06:37 PM   #8
Panther140's Avatar
The engine that I have in my car loses oil at a really fast rate lately, but only when I drive it hard. (which is usually).
I notice that when I pop the hood after I drive it, the dip stick is popped out completely and resting on top of the tube. I put it back in and checked it the next day after a spirited drive, same ****.
But I figured out the easiest way to fix it.
Remove the hood, disconnect the electrical from the engine, pull the heater hoses off, pull the fuel line off, pull the vaccum hoses off, disconnect the power steering pump, AC compressor, exhaust, and transmission, hook an engine hoist up to it, crank it up, move it over a few feet, drop it off a cliff, hook up to a new engine, bring it over to the car, and reconnect everything. Works every time garunteed and costs less than $500!
Panther140 is offline   Reply With Quote
Old 12-22-2014, 12:55 PM   #9
Boosted_3v's Avatar
Lmfao!
Old 12-22-2014, 03:50 PM   #10
If its freshly rebuilt and burning oil like crazy then it needs to go back to the builder for a warranty. If HE did the rebuild... well he's going to have to tear it apart and redo it or pay someone who knows what they are doing.
Old 12-22-2014, 04:23 PM   #11
Wow this is awesome advice. Almost got in trouble for laughing in safety meeting
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
Oil burning/lots of air coming from oil cap tage 1996-2004 Mustang GT 5 12-18-2012 06:55 PM
Burning oil.. Storm13_5.0 1979-1995 Mustang GT 19 05-27-2012 06:42 PM
Burning oil Redstang1 2011-2014 Mustang GT 17 02-06-2012 05:54 PM
4.6 2002 burning oil. tonyjuan 1996-2004 Mustang GT 23 11-27-2010 04:31 PM
» Members Mustangs
Avengnd
avengnd
RED
jmeigs
Add your Mustang
06:31 PM
