Converible help! - Mustang Evolution
Old 12-22-2014, 04:33 PM   #1
Jay180's Avatar
Converible help!
So I put transmission fluid (Mercon V) in my convertible motor and everything was working fine. The top went up and down as it should, then I put my seats back in and tried to put my top up and it doesn't go up. There's no noise or anything at all it won't go up. E-brake light is on as well.
Jay180 is offline   Reply With Quote
Old 12-22-2014, 04:47 PM   #2
yellowconve's Avatar
check the fuses if not i would suggest get a volt meter and check the switch to see if that is it.
yellowconve is offline   Reply With Quote
Old 12-23-2014, 06:51 AM   #3
runvsofthisbull's Avatar
Might be a dumb question but when you refilled the pump did you disconnect the harnesses? If you don't here anything (the pump cycling the lift cylinders) this could be the issue.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 12-27-2014, 12:03 PM   #4
Jay180's Avatar
No I didn't disconnect anything
Old 12-27-2014, 12:35 PM   #5
GrabberMeBlue's Avatar
Converible help!
Take your seats back out. Does it work again?
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 12-30-2014, 06:19 PM   #6
Jay180's Avatar
Well it works now, somewhat when it wants to. But it doesn't fit right. It bends inward when it's all the way up
Old 01-02-2015, 05:17 AM   #7
Is the fluid leaking from the lift cylinders? Do you have any fluid either under the rear seat or on the floor (sometimes one just goes bad)? If one side goes up faster than another it could be because one of them is going bad and doesn't have the correct pressure due to a leak. I replaced both of mine about a year ago since the top stopped going up do to one leaking badly (the o rings just give out after 5-10 years). If either of the lines are kinked that would cause it too. Lastly is the pump grommet back in? I know that thing is a PITA and it likes to pop out.
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
03:56 PM
