97 running hot - Mustang Evolution
Old 12-22-2014, 07:20 PM   #1
97 running hot
I replaced the engine, radiator, and thermostat on a 97 mustang gt but it's still running hot. Can anyone help?
caulderk is offline   Reply With Quote
Old 12-22-2014, 07:48 PM   #2
Is your intake manifold cracked
Bigshow14 is offline   Reply With Quote
Old 12-22-2014, 07:51 PM   #3
I will check. Anything else?
Old 12-22-2014, 09:42 PM   #4
Verify that the cooling fans are coming on.
Does it get hot all of the time? Highway driving? City driving? Idling?
Old 12-23-2014, 12:31 AM   #5
phillip433's Avatar
Did you install your thermostat upside down ?
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 12-23-2014, 02:26 AM   #6
Make sure you're not making coolant
Sent from my 0PCV1 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 12-23-2014, 11:41 AM   #7
Speed_Mister's Avatar
Region: Arkansas
Check your fan fuse and relay. Or the fan itself.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-23-2014, 12:25 PM   #8
ultrawhiteSN95's Avatar
Almost every reply here could be the reason for your car running hot bro, here are a few more options:
Make sure your drive belt is not old/ or dry rotted and about to break
Another one could be the water pump is about to go out
fan cluth
heater core needs to be replaced or flushed
1998 GT, Edelbrock Victor Jr. Ford 4.6L SOHC, Edelbrock Fuel Rails, 1999 Gt Engine w/ PI Heads,Accufab 70mm TB & Plenum,Fuel Pressure Regulator 515 Series Inline Return Style, 25-90 psi, Underdrive Pulleys,MSD ignition coils ,4.10 gears,Diablo Sport Predator Tuner
ultrawhiteSN95 is offline   Reply With Quote
Old 12-23-2014, 12:34 PM   #9
Now they are saying it's building too much pressure. Why would that be?
---------- Post added at 02:34 PM ---------- Previous post was at 02:33 PM ----------
The person that put the engine in did block the heater coil. Could that be it?
Old 12-23-2014, 11:34 PM   #10
might be a blown head gasket
Old 12-23-2014, 11:42 PM   #11
Yes if he didnt connect the heater hoses together to complete the circuit that will cause it to overheat.
Hot hot! OutlawGT 2.3 Mustang 7 12-04-2011 10:39 PM
running hot 04TRV6 Pre-2005 V6 Mustang 13 06-22-2011 06:33 AM
Running Hot Gray Ghost 1979-1995 Mustang GT 13 01-14-2011 12:02 AM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 08:01 PM
Running Hot.... Shortie630 Pre-2005 V6 Mustang 12 03-25-2004 10:19 PM
04:23 AM
