Create Ram Air Hood? - Mustang Evolution
Old 12-24-2014, 06:40 PM   #1
SquatchMan's Avatar
What do you guys think about making a stock 04 GT hood a ram air? Would that be a good idea? Or is it just a stupid thing I should stay away from?
40th Anniversary GT
04 GT
SquatchMan is offline   Reply With Quote
Old 12-24-2014, 06:47 PM   #2
Laquisha's Avatar
Dumb idea
Naturally Aspirated Is Lyfe
Old 12-24-2014, 10:58 PM   #3
Mile high JDF's Avatar
It's been done before, but the issue you're gonna run into is the factory scoop isn't held on very well and already has a tendency to fly off even without making a hole into the engine bay for air flow. Your best bet is to get a Mach 1 setup or buy one of the aftermarket ram-air Mach 1 hood kits.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-24-2014, 11:40 PM   #4
There is a support inside of the hood scoop mesh area, it connects down and is what keeps the scoop on. When people take out the mesh that's when you lose the support and it flies off.
If you really want it functional. Cut a hole in the hood from the bottom. Then drill holes through the mesh area to the part blocking it, but leave the mesh in.
Also the only thing that'll do is blast air into your manifold, which really won't do anything since it won't get hot enough, unless you are supercharged with a twin screw. Also it'll get super dirty. If you want it to be functional the right way and feed air to the intake you want a Mach 1 hood and shaker.
Ram air hood cgibbs7 2005-2010 Mustang GT 7 01-27-2015 05:19 PM
Stock vs Ram Air vs Cold Air Intake Slow4V 1996-2004 Mustang GT 6 04-17-2014 10:02 PM
How much to get 2014 V6 Air Ram hood painted deep impact blue about? Devin337 General Mustang Discussion 3 12-19-2013 11:18 AM
Ram 2500 :: 2003 Dodge Ram 2500 95YellowGT_5.0 Member Garages 0 06-15-2011 12:01 PM
Ram air fibre glass hood primer2tone 2011-2014 Mustang GT 11 12-14-2010 04:28 PM
10:01 PM
