2001 ford mustang gt over heating water leaking from bottom? - Mustang Evolution
Old 12-26-2014, 09:39 AM   #1
Krisis187's Avatar
Region: Nevada
I have a 2001 Ford Mustang gt with a fairly new radiator. It started running hot on the freeway and I pulled over and water was gushing Out of the bottom of the car. I put cold water in the radiator and it didn't over heat but it still ran out some when I made it home. I only drive 2.1 miles after putting the water in it does any one know what it is? Please bros
Krisis187 is offline   Reply With Quote
Old 12-26-2014, 03:27 PM   #2
You really are going to have to do some detective work and find out where is coming from. Plastic intakes are notorious for leaking, could be a hose, the coolant tube under the intake, water pump, a headgasket etc...
Old 12-26-2014, 06:25 PM   #3
Could be your water pump check that
Lainez1217 is offline   Reply With Quote
Old 12-28-2014, 03:42 PM   #4
joe_117's Avatar
Heater core.
joe_117 is offline   Reply With Quote
Old 12-28-2014, 04:34 PM   #5
Originally Posted by joe_117 View Post
Heater core.
Leaking externally? No.
Old 12-28-2014, 08:50 PM   #6
joe_117's Avatar
Mine leaked internal and external. It leaked from the firewall. Fixed it up and it stopped leaking. Does your heater smell funny when it's on?
Old 12-28-2014, 08:59 PM   #7
Billgluckman's Avatar
Man you're gonna have to narrow it Down To at least an area from which leak is coming from..
And to the poster who diagnosed a bad heater core..just because this happened to you doesn't mean it's what's going on now. This is what's wrong with searching the Internet to diagnose problems.
It could be the heater core leaking at firewall, it could be many things.
Billgluckman is offline   Reply With Quote
Old 12-28-2014, 09:31 PM   #8
Then more than just the core was shot, was the lines too or it failed literally right at the firewall. He'd have fluid in the car too if this was the case.
Its likely a cracked intake or a blown out coolant line somewhere but gotta get some more troubleshooting.
Old 12-28-2014, 09:39 PM   #9
The pipe of the heater core, sticking out of the firewall, is a common failure. Not just on these engine but on many. So it could be a heater core. But there's no way of knowing.
I see what your getting at though, it could be as simple as a hose.
2001 ford mustang gt over heating Krisis187 1996-2004 Mustang GT 2 09-10-2013 06:07 PM
1985 mustang over heating 1985MustangH3LL 1996-2004 Mustang GT 3 07-04-2012 11:45 PM
Why is my Mustang Over Heating?? quigley General Mustang Discussion 4 03-08-2010 06:51 AM
1995 Mustang GT 5.0 over heating any idea? gil 1979-1995 Mustang GT 7 08-23-2009 12:42 PM
Please Help...I'm going in circles. New engine, over heating and missfiring. rob4292 1996-2004 Mustang GT 4 05-31-2007 02:15 PM
02:28 PM
