What the hell did I do? (DPFE SENSOR) - Mustang Evolution
Old 12-27-2014, 10:33 AM   #1
HighlyBored's Avatar
Installing a new DPFE sensor as my last attempt of clearing my P0401 code. I wiggle the first of the two tubes connected to it free, and it just drops through to the ground. Does this hose even connect to anything? If it does it certainly was not when I removed it from the original DPFE.
Pic included in next post.
HighlyBored is offline   Reply With Quote
Old 12-27-2014, 10:34 AM   #2
This is the hose in question. I have it on the respective port it connects to on the new DPFE which I did not put on yet. This is for reference. Does this hose connect to anything besides the DPFE?
It's the HI port as opposed to the REF port if that helps.
Old 12-27-2014, 12:15 PM   #3
Figured out that it is supposed to be connected to the EGR tube like the other one. Got it connected but barely because the tube is like an inch or so short. I doubt it will be connected for long...
Fired up the car, still have the same code. I disabled it but I'm sure it will be back. I officially give up on it if it does.
Sent from my SM-G900T using Mustang Evolution mobile app
Old 12-28-2014, 01:07 PM   #4
phillip433's Avatar
A lot of f150s with the 2v 4.6 have this problem. It's a common problem. But my friend went through this much trouble. Changed a lot of unnecessary stuff and something stupid fixed it. I forgot what he changed but it worked. When I get a chance I'll find out. But there's a lot of forums on the web bout ole p0401.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 12-28-2014, 01:19 PM   #5
Yea I'm completely out of ideas. New valve, cleaned the throttle body/plenum, and now I replaced the dpfe. Still have the code I have no idea what's going on.
Old 12-28-2014, 09:31 PM   #6
Billgluckman's Avatar
If that was disconnected then that explains your code. (That is an egr cod right? And this hose connects to the egr tube didn't you say?)
If that hose is too short, buy a hose that is long enough.
Billgluckman is offline   Reply With Quote
dpfe sensor upgrade. Chelley Pre-2005 V6 Mustang 1 09-09-2013 07:32 PM
DPFE sensor for 2001 convertible Rufus1965 General Mustang Discussion 0 03-25-2011 11:29 AM
2001 DPFE replacement oyarsa Pre-2005 V6 Mustang 5 11-07-2008 09:10 AM
2002 Mustang dpfe sensor SonikBlueStang Pre-2005 V6 Mustang 4 04-17-2006 08:45 PM
DPFE sensor MUSTANGJUNKY420 Pre-2005 V6 Mustang 3 08-01-2003 09:15 PM
09:56 PM
