transmission - Mustang Evolution
Old 12-28-2014, 07:12 AM   #1
Region: Rhode Island
transmission
I have a 2004 GT. It has a manual trans 5 speed. I have 70000 miles on the car and went thought 2 transmissions. I'm not hard on the car. Can anyone tell me what is the best trans for that car. I need something that will hold up.
bigfoot890 is offline   Reply With Quote
Old 12-28-2014, 11:16 AM   #2
joe_117's Avatar
Tr3650? Am I correct?
joe_117 is offline   Reply With Quote
Old 12-28-2014, 11:18 AM   #3
TR3650 is what he has. Which is a pretty good transmission.
I think the better question to ask is why are you going through that many transmissions?
Old 12-28-2014, 12:17 PM   #4
irishn8's Avatar
Ya thats certainly odd to go through 2 TR3650's while driving easy...
Theres got to be something else going on here
Old 12-28-2014, 12:59 PM   #5
Did they come overfilled?
Sent from my 0PCV1 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 12-28-2014, 01:07 PM   #6
Yea they do come overfilled. But that's every single 01-04 5 speed from the factory, it hinders shifting but usually hasn't destroyed transmissions.
Old 12-28-2014, 01:08 PM   #7
Also, OP. To what extent were the transmissions damaged or needing replaced?
Old 12-28-2014, 01:19 PM   #8
Rapinator126's Avatar
Think a major driver mod is in order.
Old 12-28-2014, 05:07 PM   #9
Or a new clutch and flywheel setup that is properly aligned.
Old 12-28-2014, 06:11 PM   #10
Trans
The problem was the oil is foaming. When they put the second trans in the ford com. said to keep it a quart lower. They even put a sticker on the trans saying that. When I got the new trans 5 gear was bad from the start. I went to them twice and they blow me off. They said it was the tires causing the vibration. Two years letter 5 gear went. I knew it would. And it did. I want to get a 6 speed don't like the 5. What's the best trans to get.
Old 12-28-2014, 06:42 PM   #11
smurf stang's Avatar
Maybe bad mounts so it's not lining up correctly?
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 12-28-2014, 06:48 PM   #12
You got a bad trans from the start like you said. Shop screwed you. A good 3650 is a real great transmission that will last a long time and shift well. You want the best? Get a Tremec Magnum. For $5k...
I got a rebuilt 3650 for my old 98 for $1060 shipped, installed it and it was awesome right off the bat.
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
Automatic Transmission Question? TriStateStang Pre-2005 V6 Mustang 10 01-24-2008 12:54 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
Transmission Stuff Laser02 Pre-2005 V6 Mustang 4 11-15-2003 01:03 PM
Transmission vigiracer Pre-2005 V6 Mustang 2 07-20-2003 01:47 PM
02:04 AM
