Parked for winter - Mustang Evolution
Old 12-31-2014, 08:46 AM   #1
ryank64's Avatar
Parked for winter
Hey so I got my 2000 GT parked for winter I haven't started it in like 2 months is that ok so I be worried
Sent from my Nexus 5 using Mustang Evolution mobile app
ryank64 is offline   Reply With Quote
Old 12-31-2014, 09:14 AM   #2
GrabberMeBlue's Avatar
You're better off not starting it every so often. Just leave it until Spring.
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 12-31-2014, 09:17 AM   #3
ryank64's Avatar
I won't have oil leaks or anything
Old 12-31-2014, 09:19 AM   #4
Roguestang's Avatar
I don't live in a cold climate, but I do leave for work often. I always make sure I have some fuel sta-bil in the tank, and a float charger on the battery. Some check the tires so they don't get flat spot too, but unless it's sitting a very long time I don't think that it's a big deal.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-31-2014, 09:23 AM   #5
Seems like I had more of an issue with that on my '79. That hasn't really been an issue on my '95. Maybe just lucky, or maybe an age thing.
1979 Gold Trans Am
Old 01-01-2015, 02:45 AM   #6
Speed_Mister's Avatar
Region: Arkansas
Actually that's how stuff breaks more often. It's made to run not sit for a long period then run. I would start it maybe every week and let it get a little warm and maybe drive it every so often. Had a buddy let his gt sit for a while drive it and his rear-end went out.
2004 Mustang GT 5 Speed Full Bolt On 360rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 01-01-2015, 05:59 AM   #7
kingstrider's Avatar
I park my car in the garage and under a cover. Overinflate the tires a little, battery tender, full tank with fuel stabilizer, not much else needed. Most people agree it is more detrimental to start the car on occasion and let it idle or for a quick drive around the block. This doesn't get all the fluids up to temp and will cause rusting within the exhaust system. Unless you drive it say 10-20 miles or so then its best to leave it parked.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 01-01-2015, 04:57 PM   #8
If you don't have a garage it really should be driven. If it's outside at least cover it and bring the battery inside and keep it on a trickle charger and make sure the car has a full tank of gas with stabil.
Old 01-01-2015, 05:29 PM   #9
I would recommend a battery tender over a trickle charger. I had a trickle charger cook a battery a few years back. Came home and found the battery in one of my cars smoking.
1979 Gold Trans Am
Old 01-01-2015, 05:39 PM   #10
I meant tender. I know they are different. I ran a $12 interwebs special for years with no issues.
Old 01-01-2015, 05:53 PM   #11
Yeah, I use the Deltran Battery Tender Junior. Inexpensive and safe.
1979 Gold Trans Am
Old 01-05-2015, 02:11 PM   #12
ryank64's Avatar
Ya its in my garage just haven't started it for awhile so I was worried
Old 01-05-2015, 06:56 PM   #13
Steve96's Avatar
I have used a full tank of gas, stabil, overfill the tires a little, park on old carpet squares, disconnect the battery and have had no issues parking it now for 4 seasons. Still on the same battery I bought it with 4 years ago. Just clean it off from time to time with spray detailer as I'm in the market for a new car cover
1996 GT
Old 01-05-2015, 06:57 PM   #14
Steve96's Avatar
And usually a fresh oil change if it needs one. And change it again in early spring after getting it on the road again.
1996 GT
Old 01-05-2015, 08:33 PM   #15
ryank64's Avatar
I'm start it tommorw anything I should do before I start it
Old 01-05-2015, 08:35 PM   #16
natestang07's Avatar
If you start it drive it.
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 01-05-2015, 10:44 PM   #17
Steve96's Avatar
Yeah if your going to start it periodically I would drive it for 10 miles at least to let everything get to temp. All fluids etc to temp. It's better to get them ready, park them and start them in the spring. I've always heard it is better to just let them sit anyway depending on how long etc.
1996 GT
Old 01-06-2015, 06:31 AM   #18
My 95 Cobra and 98 GT both sat from pretty much Nov-March/April every year without being started. As long as the proper prep is done, its better just to leave them on a tender with a tank full of stabil'd fuel. I would even put them up on jackstands to unload the suspension and keep the tires from getting flat spots.
Old 01-06-2015, 02:01 PM   #19
ryank64's Avatar
Well its been sitting for 3 months cuase there's snow I can't drive it still to deep of snow but can't I start it
Old 01-06-2015, 02:02 PM   #20
ryank64's Avatar
Buddy told me seals could dry up and I'm just rly worries
Old 01-06-2015, 03:19 PM   #21
Steve96's Avatar
Go ahead and start if you want to. It will be fine, let it run long enough to get up to temp. I dont think it has been sitting long enough to cause everything to shrink
---------- Post added at 05:19 PM ---------- Previous post was at 05:19 PM ----------
Or dry up
1996 GT
Old 01-06-2015, 03:44 PM   #22
Or dry up
I was always under the impression if you can't drive it after starting it it is better to just let it sit.
Old 01-06-2015, 04:51 PM   #23
Steve96's Avatar
Yes me too. But if he is insistent on starting it then so be it. If you see my previous posts you will see I mentioned the same thing. If he starts it once in the middle I'm sure it won't cause any earth shattering issues, Also if he doesn't start it either it won't. Everyone may be being overly critical at this point on this specific thread.
1996 GT
Old 01-06-2015, 04:57 PM   #24
Touche my good sir. Op do what you want
Leaking coolant when parked rollo1987 1996-2004 Mustang GT 5 08-25-2014 06:27 PM
Does your anti-theft light flash when the car is parked? escottcarp 1996-2004 Mustang GT 7 12-12-2013 04:42 PM
Battery drained after 1 week parked the_stig 2011-2014 V6 Mustang 2 08-05-2012 08:35 PM
parked Devil5711 2005-2010 V6 Mustang 0 01-10-2012 03:43 PM
storm+parked under tree=owned Bane- Pictures and Videos 2 06-02-2006 12:05 PM
12:44 PM
