Subframe connector installation cost - Mustang Evolution
Old 12-31-2014, 05:52 PM   #1
The_Chech's Avatar
So today I went to get my subframe connectors installed. I went to a place my friend uses for a lot of custom welding he uses for his cars and other peoples projects. Long story short the guy doing the welding had no gas to even do half of the job so we didn't event start. But in the end after he saw what all needed to be done and welding onto the car he quoted me 500-600 to have both sides done. He said it was going to take him 5-7 hours to finish. This kind of blew me away honestly.
So what has every one else payed to have theirs welded on?
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 12-31-2014, 05:55 PM   #2
Find a buddy who can weld. Tyoung68 did mine so it was free
Old 12-31-2014, 06:20 PM   #3
The_Chech's Avatar
Might try the hobby shop on base and try my hand at some welding
Old 12-31-2014, 06:21 PM   #4
Slater2111's Avatar
That's pretty high. You don't need to run a bead the whole length of them. Even if you did that's still pretty high. I can weld but I am choosing to have them welded in by a shop and they quoted me $80 they said it probably wouldn't take long at all
Slater2111 is offline   Reply With Quote
Old 12-31-2014, 07:05 PM   #5
Steve96's Avatar
My brother had his done a few years back and cost him 80 bucks so I'm sure a little more now days.
1996 GT
Old 12-31-2014, 08:54 PM   #6
The_Chech's Avatar
Looks like I'll be making a few calls around my area but if every one quotes over 200. I think I'll be tackling this my self
Old 12-31-2014, 09:38 PM   #7
smurf stang's Avatar
Call some muffler shop. No more than $100 max
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 12-31-2014, 10:01 PM   #8
Mile high JDF's Avatar
I paid $100 for mine and it took 3 hours with a break for dinner and jacking up the car instead of driving it onto a drive-on lift
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-31-2014, 10:18 PM   #9
Slater2111's Avatar
Trying your hand at welding isn't the best idea on the underside of your car and definitely not on subframe connectors. This ain't a lengthy in depth job. But it does require skill and knowledge. Also try to avoid doing it on jack stands. If you tweak the frame even slightly you'll notice. A drive on lift is the only way to do it right. You shouldn't have to pay anything over $100. Call around to muffler shops and try to find someone that will do it.
Old 01-01-2015, 10:26 PM   #10
Had mine installed two weeks ago, my Brother put them in place and bolted them up marked where they touched the car and took a grinder and cleaned off the paint all for $40.00 and then I paid a master welder $50.00 to do welding.
Landspeedracer is offline   Reply With Quote
Old 01-03-2015, 08:57 AM   #11
edross's Avatar
I paid 300 to have mine welded
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 01-03-2015, 09:49 AM   #12
Speed_Mister's Avatar
Region: Arkansas
Had a shop welded mine in for 100$
2004 Mustang GT 5 Speed Full Bolt On 360rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 01-04-2015, 09:09 AM   #13
Costs $200 around me from a shop that includes a roll on epoxy coating to keep them from getting crudded up. Agreed with other posters, this is NOT NOT NOT the area you try out your welding skills on. Needs to be done properly and done properly the first time.
Hotchkis subframe connector 4016 goohead 2011-2014 Mustang GT 0 04-13-2014 12:33 PM
Mustang subframe connector bolt on kickerofdoom 1979-1995 Mustang GT 10 09-13-2013 06:50 PM
Subframe Connector Install Travis B 1979-1995 Mustang GT 13 12-16-2011 09:08 PM
subframe connector kickerofdoom Pre-2005 V6 Mustang 1 04-11-2011 04:04 PM
11:07 AM
