head swap - Mustang Evolution
Old 01-01-2015, 06:00 PM   #1
Question head swap
Alright i have a 97 4.6 gt im thinking i can but want someinput will the 01 model mach 1 4 valve heads bolt on
clintoncmm09 is offline   Reply With Quote
Old 01-01-2015, 08:48 PM   #2
Billgluckman's Avatar
You'll lose compression. Just build from scratch and use the appropriate pistons.
Billgluckman is offline   Reply With Quote
Old 01-01-2015, 09:13 PM   #3
Well im going to be adding a turbo in the next month so that won't matter
Old 01-01-2015, 09:30 PM   #4
Then yeah..they'll bolt on
Old 01-01-2015, 11:31 PM   #5
smurf stang's Avatar
More than just a head swap then you are building for boost.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 01-02-2015, 09:07 AM   #6
Panther140's Avatar
Are you going to be running relatively low boost? If you are going to run over 8/9 psi then I don't see why you get the 4v head when you can just max out the engine internals strength with boost anyways?
I could be wrong, but you probably cant put more than 400 rwhp with the stock rods and pistons. You can hit 400 rwhp pretty quick if you have a good turbo. Instead of getting the 4v heads, I would upgrade your clutch, rear end, or rods so that they are ready for boost.
I probably sound like too much of a nay-sayer though. a 4v head swap is cool no matter what you're set up is and the HP gains from it will be doubled if you boost it at 15 psi
Panther140 is offline   Reply With Quote
Old 01-02-2015, 03:17 PM   #7
Yeah I'm not going to be thrown no big 15 20 psi boost into it maybe 10 psi max right now and I'ma be rebuilding the engine like internals later on just want to start getting the cheaper stuff right now
<head></head> Earings Brent The Bar 10 06-02-2007 11:48 AM
Intake and head swap!?!? JERIC Pre-2005 V6 Mustang 6 09-13-2004 06:48 PM
PI head/Intake Swap Info needed bluemustang 1996-2004 Mustang GT 7 02-28-2004 10:17 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
Head 2 Head battle Angel The Bar 14 08-11-2003 09:29 PM
04:51 PM
