Rear end ideas - Mustang Evolution
Old 01-02-2015, 03:30 PM   #1
Rear end ideas
So wanting to see what everyone's opinions would be im gong to be doing some major motor work and going to be doing a new rear end soon don't know if I should just change the gear ratio if so what gear ratio but aldi thinking on just going to a 9in rearend
clintoncmm09 is offline   Reply With Quote
Old 01-02-2015, 03:32 PM   #2
You don't need a 9 inch. Just go with some Moser 31 spline axles and an Auburn or Eaten locker if you really want to launch hard.
Old 01-02-2015, 03:40 PM   #3
Only reason I was thinking of a 9in is because them things are indestructible. Yea I want to do a locker cause im tired of this lsd I think it's giving out
Old 01-02-2015, 03:43 PM   #4
They are practically indestructible. A set up 8.8 like I said you can run well more power than you can dream of and it won't break.
Old 01-02-2015, 03:45 PM   #5
Alright sounds good
---------- Post added at 04:45 PM ---------- Previous post was at 04:45 PM ----------
How much do you know about rearends
Old 01-02-2015, 03:48 PM   #6
Not really my special area, but they are pretty basic.
Old 01-02-2015, 05:01 PM   #7
I think my axle bearings are gong out but not sure
Old 01-02-2015, 05:10 PM   #8
Those are like $45
Old 01-02-2015, 06:57 PM   #9
Well I work at autozone so only $20 for me but not to sure if its them making the sound
Old 01-02-2015, 08:29 PM   #10
The real advantage to a 9 inch rear end, other than their phenomenal strength, is the ability to set up a few different gear ratios, in different center sections, so that the gear ratio is correct for the track conditions. The center section is relatively easy to remove and exchange with another center section with a different gear ratio already installed. It's not really necessary in street or drag racing cars but it can be beneficial on road course cars and especially on both dirt and paved oval race cars, to be able to quickly adjust the gear ratio at the track.
A Ford 9 inch is a sort of "Poor man's" quick-change rear end.
I don't know of anyone on this website that has a car that is putting out enough power where they would have to upgrade to a 9 inch. The 8.8 is very strong. Ford replaced the 9 inch rear end with the 8.8 because it is less expensive to manufacture the one-piece rear end as opposed to the two-piece 9 inch. The 8.8 is used in all of the applications that the 9 inch was used in and it performs quite well.
A nodular case 9 inch is undeniably stronger than a 8.8, and the versatility is great for some applications, but I would just stick with the "beefed-up" 31 spline 8.8 until I, literally, grenaded at least a couple of differentials.
Old 01-03-2015, 10:07 AM   #11
Well damn
Small bit of front end damage.... Any ideas? Spade_N9ne 1996-2004 Mustang GT 7 10-05-2012 10:13 PM
Ideas on parts and ideas for mods Mrsnow 1996-2004 Mustang GT 6 01-27-2012 01:13 PM
4.6 bottom end rebuild. Ideas please SonicBlueGT9963 1996-2004 Mustang GT 10 10-31-2011 07:12 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
» Members Mustangs
Goldy
Rosco3
Caronte
Caronte
Add your Mustang
04:27 AM
