Transmission leak - Mustang Evolution
Old 01-03-2015, 04:35 AM   #1
Transmission leak
Have a leak were the drive shafts and tranny meet, any idea what it could be and cost? Mach 1 with 5spd.
gbmach1 is offline   Reply With Quote
Old 01-03-2015, 12:13 PM   #2
irishn8's Avatar
Theres a seal right in there. Dont know cost but i wouldnt think it would be too much. $100 most?
Old 01-03-2015, 12:45 PM   #3
That seal in the picture is relatively inexpensive and easy to replace.
Many of the TR3650's were overfilled from the factory so you might try draining the transmission and refilling it with precisely 3.2 quarts of a high quality, Mercon compatible, synthetic automatic transmission fluid.
Old 01-03-2015, 06:39 PM   #4
Rear seal. There is a puller you need to do it and it can be done with the trans in the car. Unsure how much the puller costs but I know you can borrow/rent it from a user on the corral, just forget his SN.
Old 01-03-2015, 09:24 PM   #5
You people are awesome, thank you for your reply.
Old 01-04-2015, 10:15 AM   #6
Panther140's Avatar
All you have to do is drop your drive shaft. There are 4 12 point 12mm bolts that hold it onto the rear diff in case you didn't know. You will have a much easier time with them if you have an extender, a swivel, and then the socket.
Panther140 is offline   Reply With Quote
Old 01-04-2015, 10:29 AM   #7
He needs an actual rear seal puller though, for the tailshaft seal. You can't just dig it out with a screwdriver or something. Ford makes it but its like $100+. You can rent them if you know where to look. Either way its still better than taking it to a shop. Or maybe not... could always find a local mechanic and tell him exactly what needs to be done and say you are providing parts and just need the install.
transmission leak/vent? BeachMonkey100 2005-2010 Mustang GT 2 03-11-2013 07:28 PM
Transmission cooler line leak 2000v6stang Pre-2005 V6 Mustang 0 01-04-2013 08:20 AM
Transmission leak? Timm04 General Mustang Discussion 3 01-09-2012 11:59 PM
How do you repair a front pump leak in the transmission on a 1999 v6 mustang? napier29 Pre-2005 V6 Mustang 0 03-24-2010 04:00 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
11:31 AM
