96 GT PI Swap Recommendations? - Mustang Evolution
Old 01-08-2015, 12:03 AM   #1
Steve96's Avatar
I'm going to be doing a full PI swap on my 96 GT later this winter or early spring. PI heads, either used gone through heads or new FRPP heads. New PI FRPP intake, then either used PI cams or possibly mild cams and of course all new head bolts, gaskets, etc. My biggest question is if I do upgrade to a different cam, what else would I need? I figure valve springs for sure? Also may do 24lb injectors as well, if there are any gains to be had there that is. Just looking for some advice on the cam set up and if It's worth it to upgrade the cams. I will Also be doing a tune afterwards, possibly a MPT or a custom dyno tune locally. Oh Also I know I need the alternator bracket. Anyone know of any complete kits for this swap?
1996 GT
Old 01-08-2015, 12:21 AM   #2
Steve96's Avatar
Things done to my car now: throttle body, Plenum, CAI (may put stock back on), March underdrive pulleys, BBK off road X pipe, Magnaflow Magnapack mufflers welded in, Ford Racing 410 rear gear, H&R supersport springs, heavy duty shocks/struts, staggered 17x9-17x10 wheels.
1996 GT
Old 01-08-2015, 12:23 AM   #3
Steve96's Avatar
Also Maximum Motorsports CC plates installed. After the swap I will focus a little more on my suspension with sub frame connectors, and maybe LCAs.
1996 GT
Old 01-09-2015, 09:31 AM   #4
Steve96's Avatar
Nothing?
1996 GT
Old 01-09-2015, 10:39 AM   #5
fenixignition's Avatar
theres currently a few head and engine swap threads going on right now, i would read through those and enter that discussion since the ones who are knowledgable are all there.
2002 GT 5sp. 16x,xxx miles
Old 01-09-2015, 11:09 AM   #6
Steve96's Avatar
Thanks buddy. I did read through those. I know what I need exactly. My main question is if I were to upgrade to a stage 1 cam set up, what else will I need?
---------- Post added at 12:09 PM ---------- Previous post was at 12:08 PM ----------
I may just stick with the PI cams
1996 GT
Old 01-09-2015, 11:16 AM   #7
iirc, whenever you upgrade cams, you wanna replace the lifters and stuff. they break into eachother after some use, and i think someone here ended up with one breaking on him because he didnt change them. it was a 05 to 09 i think.
Old 01-09-2015, 01:56 PM   #8
Steve96's Avatar
Thanks for the info. That's what I was thinking. That I would have to get new valve springs, and possibly lifters. Also may have to have the cams degreed so there aren't clearance issues. Most of what I have found on the stage 1 cams say that there isn't clearance issues but some do? Probably easier to just stick with the stock cams and the money I will save I can get new heads by not messing with aftermarket cams. That little bit more hp and idle is tempting though.
1996 GT
Old 01-09-2015, 09:20 PM   #9
smurf stang's Avatar
Now would be a good time to get some long tube headers.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 01-09-2015, 09:38 PM   #10
Steve96's Avatar
I was thinking about that also. Get the long tubes and just use the stock cams that come with the heads, but I don't have a budget for it all! Lol.
1996 GT
Old 01-10-2015, 08:45 AM   #11
Roguestang's Avatar
Comp 270 video http://youtu.be/QCrwsynDf3o
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 01-10-2015, 08:46 AM   #12
Roguestang's Avatar
I've got a buddy who did comp 270's and they sound great. He did upgrade his lifters though, and it was already a PI car. Decent power increase in the mid range, but mostly that sound was what he wanted lol
I'd look for a used set of pi heads, used 270 cams, new lifters, and new guides and chains since you're already in there. Some Lt's would compliment them nicely. Then call it a day. Any job involving cams on 2v is going to be pricey. So I'd save up if need be and do it right the first time (assuming you want cams and pi heads are a non negotiable)
Old 01-10-2015, 09:50 AM   #13
Steve96's Avatar
Yeah they sound great. Thanks for the video. Now it makes me want to do it all lol.
1996 GT
Old 01-10-2015, 02:30 PM   #14
Roguestang's Avatar
Lol hey you're already in there, might as well do it all at one time
Old 01-10-2015, 03:01 PM   #15
Nothing?
Have you upgraded your fan and radiator to the 97-up style. If not this would be a good starting point prior to the swap.
Bigshow14 is offline   Reply With Quote
Car delivery recommendations PureVenom The Bar 12 05-22-2007 03:27 PM
C/C plate recommendations BlueDonkey Pre-2005 V6 Mustang 3 07-15-2004 07:04 AM
CAI Recommendations Seph Pre-2005 V6 Mustang 34 05-15-2004 11:36 PM
computer upgrade recommendations, more help tire The Bar 10 12-27-2003 02:33 PM
need recommendations... 35thAniVertible Pre-2005 V6 Mustang 3 09-15-2003 06:26 PM
» Members Mustangs
Dakuda
Konawin
Sally
Beau
Add your Mustang
09:05 AM
