Power problem/Starting up - Mustang Evolution
Old 01-09-2015, 04:11 PM   #1
Exclamation Power problem/Starting up
Hi all, new to the forums been having a issue lately with my 04 gt, The power just completely cuts out after trying to start it after turning if off. I did some things that I thought were culprit like changing batter, checking terminal connections, checking alternator but just no luck. It also makes a clicking noise as you can hear in the video near the dash. I'm stumped at this if anyone could give some suggestions love to hear. If the video does not work on here I uploaded it to tiny. View My Video
Poros is offline   Reply With Quote
Old 01-09-2015, 04:35 PM   #2
yellowconve's Avatar
think theres a prob with the video
yellowconve is offline   Reply With Quote
Old 01-09-2015, 05:02 PM   #3
video
Here I uploaded to tiny View My Video
Old 01-09-2015, 05:03 PM   #4
Here I uploaded it on tiny if there are problems on here. View My Video
Old 01-15-2015, 11:13 AM   #5
I have a problem with my 97 mustang gt. This is the second time this has happened to me. I was driving down the road and for no reason at all it was like someone shut the fuel pump off. Car had no throttle response and theft light flashed rapidly. I pulled off on the side of the road and tried everything to start it, including taking off the batter negative and waiting, using the actual key instead of the fob to unlock doors. Nothing. With the key in the run position the theft light flashes rapidly and the cooling fan kicks on. I tried to put a Ford scan tool on it and it said it cannot communicate with the pcm. I checked fuses and they were all in good condition. They all had power to the ones related to the pcm and pats system. My dad read online that the ccrm could be at fault. Is this accurate or should I just take it in at the shop I work at?
mustanGT9497 is offline   Reply With Quote
Old 01-15-2015, 12:34 PM   #6
I think that I would also be suspicious of the CCRM. It seems like it is not supplying any power to the PCM in both of your cases, although, it may be the fuel pump that is not receiving power in the OP's car.
I can't say for sure, because this is strictly an internet diagnosis, so take that advice for what it is worth.
Old 01-15-2015, 12:54 PM   #7
fomoco4life's Avatar
Can't view either video link?!? No YouTube video? Clicking often indicates weak battery or starter problems. OP does sound like ccrm issue, $50 part and simple install, worth a shot
Old 01-16-2015, 08:08 AM   #8
my 04 did the same thing but mine was my computer located by the passenger right foot which was frying cause of my bama bank 4 chip. i would hit my computer with the tire iron that was behind my seat when the theft light went off and did what you guys said flashed and turned off. turning the key and hitting the right side of the foot well the car would start right back up sometimes i would have to keep doing it some times not. but bama fixed that
Old 01-17-2015, 01:59 PM   #9
Update. Replaced the ccrm and now the cooling fan doesn't come on, but the theft light flashes and it still doesn't start the car. Still cannot get a scan tool to connect to the pcm. When connected to the DLC it says cannot communicate with vehicle.
Power Window Problem! 93CobraGuy 1996-2004 Mustang GT 10 03-22-2011 09:04 AM
Power window and lock problem need help blzfan1963 Pre-2005 V6 Mustang 3 08-08-2008 06:35 AM
power window problem HELP !!!!! wvstang5.0ho General Mustang Discussion 7 07-08-2008 08:56 PM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
running problem less power jedwards242000 Pre-2005 V6 Mustang 7 08-01-2006 03:23 PM
02:42 AM
