Gauge problem - Mustang Evolution
Old 01-13-2015, 06:56 PM   #1
Question Gauge problem
Alright i have a 97 gt and my right side (volts, rpm, oil pressure) of the instument panel works fine but on the left hand side (gas, speedo, temp) dont work corectly. Speedo says im doing 130 when only doing 20, temp maxed out, and gas 1/2 full. temp nor the gas ever move. any ideas would be help
clintoncmm09 is offline   Reply With Quote
Old 01-13-2015, 07:08 PM   #2
Does your charging system seem to be working correctly?
Disconnect the ground cable from the battery for 15 minutes, or so, and let the computer clear it's memory. While you are waiting, make sure that the ground connection is clean and there is a good connection to the engine block. Make sure that the positive connection is clean and tight as well.
Old 01-13-2015, 07:13 PM   #3
i put new terminals and battery in the car and has new main ground cable
Old 01-13-2015, 07:17 PM   #4
Were the gauges malfunctioning prior to you replacing the cables, or did this just recently occur?
Old 01-13-2015, 07:18 PM   #5
Yeah it was like this before
Orange mamba
Old 01-13-2015, 07:25 PM   #6
Well I suppose that the cluster can fail like anything else. They are very easy to remove, so I think that I would pull It out and see if there is anything obvious wrong, like maybe it has started to come unplugged or something.
Old 01-13-2015, 07:39 PM   #7
Already put a new one on it and same
Orange mamba
Old 01-13-2015, 08:02 PM   #8
Hmmm.
Have you checked all of the fuses related to the gauge cluster?
Old 01-13-2015, 09:10 PM   #9
All the fuses are good that's why I'm stumped
Orange mamba
Old 01-13-2015, 09:45 PM   #10
There isn't any information about diagnosing the cluster in my repair manual. It must be something else anyway.
Have you checked to see if there are any stored codes? That may give an indication of where to start looking for the problem.
Also, I believe that all of the information goes through the PCM and the Constant Control Relay Module before reaching the instrument cluster, so either of those could be at fault.
I would think that, if the PCM is receiving those crazy inputs from the speed and temperature readings, it will inevitably throw a code of some sort.
2005 4 gauge cluster upgrade to 6 gauge wessstblvdd 2005-2010 Mustang GT 6 07-07-2014 08:29 AM
20 gauge to 18 gauge XXSTEVEO66 General Mustang Discussion 0 08-16-2011 06:58 PM
Gauge Wire Routing w/CDC gauge pod tripod_2005 2005-2010 Mustang GT 13 04-30-2010 11:46 AM
1995 convertable 5.0 temp/fuel gauge problem rwb223 1996-2004 Mustang GT 3 03-10-2010 12:55 AM
gauge problem red herring The Bar 5 07-11-2005 01:26 PM
04:38 AM
