New throttle body arrived today.. - Mustang Evolution
Old 01-16-2015, 10:45 PM   #1
Slater2111's Avatar
Well I received my throttle body and plenum today from AM. They are very well made and look great. However I discovered that the throttle body gasket is broken in multiple places. Can I just use some RTV gasket maker to seal it up. Or should I go to Oreilly tomorrow and see what they have?
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 01-17-2015, 06:20 AM   #2
The_Chech's Avatar
RTV will work just make sure you go on the inside of the screw holes on the plenum to avoid any leaks.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 01-17-2015, 06:36 AM   #3
Slater2111's Avatar
That's what I thought. I was just making sure. I still need to go to oreillys. So I might see what they have regardless.
Old 01-17-2015, 02:55 PM   #4
Slater2111's Avatar
I went to oreilly today and got a factory throttle body gasket. It fit perfectly. Install took about 2 hours because I had to go back up to oreilly and get a new tps after I broke it off the old throttle body. Just my luck. After everything was installed I checked it for leaks and then installed my 93P tune from MPT. The car is a whole different animal!!!!! What my old full throttle is my new 1/4 throttle it feels like!!! The car is instantly responsive!!!!
Old 01-17-2015, 04:49 PM   #5
Steve96's Avatar
I've always heard and read that the stock plenum and throttle body choked these cars.
1996 GT
Old 01-17-2015, 04:52 PM   #6
Slater2111's Avatar
They really do. The difference is night and day.
Old 01-17-2015, 05:07 PM   #7
Slater2111's Avatar
I should have gone with a 75mm throttle body though. To match the 75mm C&L plenum.
Old 01-20-2015, 09:47 AM   #8
fenixignition's Avatar
I'll finally be back to a 75mm throttle body this weekend. Right now its a stock tb with a c&l plenum. no tune yet tho :/
2002 GT 5sp. 16x,xxx miles
Old 01-20-2015, 01:45 PM   #9
Slater2111's Avatar
I wish I would have got the 75mm. But when I called AM they said it would probably cause it to big because it would get too much air. I did a ton of reading before that and read it was a myth. But I didn't want any trouble so I went with the 70mm. But I have the C&L plenum and TB tuned for the car. So I don't know how it would have bogged with the 75mm
Old 01-20-2015, 07:28 PM   #10
70 is good for naturally aspirated. 75, the difference is too meanial to notice any decline in performance, but I guess its good for boost. Idk how big the throttle bodies get for higher amounts of boost tho.
Sent from my GT-P3113 using Mustang Evolution mobile app
Vortech Arrived Today!!! 86gt 1979-1995 Mustang GT 85 07-20-2011 12:40 AM
last of it arrived today :-D dark The Bar 2 08-15-2007 02:47 PM
Stock 2002 GT Throttle Body and Plenum...End today Junior2561 Mustang Parts for Sale and Wanted 0 02-23-2004 07:08 AM
New SCT chip burned by Dennis Reinhart arrived today!! Rick0636 Pre-2005 V6 Mustang 5 02-17-2004 09:52 PM
07:10 AM
