Gathering for rear end gears - Mustang Evolution
Old 01-22-2015, 09:42 PM   #1
XSlashDashX's Avatar
Question Gathering for rear end gears
Would this all I would need for gear swap? Noticed when I swap my midpipe that my Rear End is leaking from the Gasket. So I figure I'd do gear swap.
Ford Racing 4.10 Mustang Gears M-4209-G410A (99-04 GT) - Free Shipping
Ford Racing Mustang Ring & Pinion Installation Kit - 8.8in M-4210-B2 (86-14 V8, 99-04 Cobra, 11-14 V6) - Free Shipping
Royal Purple Max Gear 75w140 Mustang Gear Oil 1301 - Free Shipping
That is the right Gear Oil, correct? For 2000 GT. Three bottles. Don't need the Friction Modifier if RP has it?
Ford Racing Finned Mustang Differential Cover - 8.8in M-4033-KA (86-14 V8; 11-14 V6, Excludes IRS) - Free Shipping
This is just for looks.
Old 01-22-2015, 10:32 PM   #2
That looks pretty complete.
You might also consider installing new clutches in the Trac-Lock differential as well.
Old 01-23-2015, 06:49 AM   #3
Will the carbon fiber clutches do from AM?
Old 01-23-2015, 07:06 AM   #4
fenixignition's Avatar
yes. They are tougher and more upgraded. supposed to be the kind they put in the gt500 and cobras. its like putting a stage 1 or 2 clutch in a stock gt. there might be some minor drawbacks, but the benefits are stronger construction and longer lasting.
otherwise there is a cheaper one without the carbon fiber. just depends on how overbuilt you want it.
2002 GT 5sp. 16x,xxx miles
Old 01-23-2015, 08:26 AM   #5
Slater2111's Avatar
Like others have stated. It looks pretty complete. And yes do put the ford racing friction modifier in there. Start with the friction mod and then fill with the royal purple.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 01-23-2015, 09:08 AM   #6
Mile high JDF's Avatar
The carbon fiber clutches are an easy install so might as well do them. I noticed no change in drive ability with mine.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-23-2015, 01:07 PM   #7
Site Sponsor
Sponsor
AMWill's Avatar
Hey Slash,
You've got everything covered!
Make sure to time some time when installing as the shimming process can get tedious but it's so worth it in the end!
What are your plans for the car next?
Thank you for your continued business and support and let me know if you have any questions!
-Will
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-23-2015, 04:12 PM   #8
Steve96's Avatar
When I had my Ford racing 410 gears installed the installer I used did not want to use the royal purple as they said they have had it damage gears before. It's a ring and pinion Shop/installer been in business 55 years. When I asked Why he said he has used it before with the Ford racing gears and has had issues. Noise and friction issues so he ended up redoing them. I don't know if this is True or not? I went with what he said and he used standard fluids and they are great and no issues. But this is the second Shop that told me the same thing. I don't know if there is anything to it or just preference? Has anyone ever heard this or been told this?
1996 GT
Old 01-23-2015, 05:30 PM   #9
Billgluckman's Avatar
I did 4.10s a few months ago and my spider and side gears needed replacing as well so be prepared for that.
Billgluckman is offline   Reply With Quote
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
gathering information straight68 Classic Mustangs 12 04-14-2008 04:56 PM
So help me out with gathering info for a speech.... Brent The Bar 12 11-18-2005 10:47 PM
05:47 PM
