Problem With Car - Mustang Evolution
Old 01-25-2015, 09:48 PM   #1
2vhulk's Avatar
Problem With Car
Hey guys So yesterday i took out "Hulk" for a little ride because i just got new 355 nittos and new brakes with a few other little things. As I was cruising testing the brakes and seeing how the car felt it turned off. The power steering got hard and everything just shut off. I stopped put her into parking cranked the engine and broom back to normal and then i got home safe without it happening again. No lights turned on, it doesn't sputter or anything. I don't think it's the battery because i just bought a new performance battery from American muscle and i put it on that same day. The alternator on the car also seem to be working okay. All fuses were tested and they are okay also. So basically i am lost.. What could have caused the for the car to turn off. The power steering stopped also the steering wheel got really hard and I managed to put it into a safe driving position because the car actually turned off as I was turning into my neighborhood. Could any of you guys give a hand of expertise here and tell me what it could possible be?
2v 4.6l V8 "HULK" project
2vhulk is offline   Reply With Quote
Old 01-25-2015, 10:12 PM   #2
509pony's Avatar
I had a similar problem it ended up being the alternator on mine.
Sent from my SGH-T999L using Mustang Evolution mobile app
509pony is offline   Reply With Quote
Old 01-26-2015, 03:25 AM   #3
fenixignition's Avatar
I couldnt tell if mine did that one day as I was comin to a stop for a left turn. It either shut off on its own, or I was derping with the clutch. But never had a single problem since that day. Like a month ago.
Sent from my GT-P3113 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 01-26-2015, 08:53 AM   #4
Panther140's Avatar
I had that happen to me on a wide open throttle pull one day :/ Not sure what it was! But it re-started just fine and I haven't had an electrical problem since.
Panther140 is offline   Reply With Quote
Old 01-26-2015, 09:40 AM   #5
Getn off's Avatar
Sounds a bit silly, but this has happened to me before on my '97. Somehow my right knee bumped the keys just at the right angle and it hit the ignition in a way to temporarily cut the engine off. Coasted to a stop. Turned her back on, and never another issue.
Troy
Getn off is offline   Reply With Quote
Old 01-26-2015, 11:37 AM   #6
I would check the charging system and make sure that everything is working correctly. If that checks out ok, the next thing to look at would be the Idle Air Control valve. If you have been noticing an erratic idle or "hanging" RPM's, it may be time to install a fresh Motorcraft IAC.
Old 01-26-2015, 12:18 PM   #7
Panther140's Avatar
I agree. Check the IAC. If you had the same issue mine did, then it probably died as you let off the gas and put the clutch in, and the RPMs dropped. Then the IAC didnt work right and let it just die. No worries for me now though, I have a carburetor! Car does exactly what I tell it to exactly when I tell it to do it.
Old 01-26-2015, 01:01 PM   #8
2vhulk's Avatar
I have been experiencing some pretty bad idle. Sometimes it's at around 700-800 and it just instantly drops down to 300 almost making the engine die
Old 01-26-2015, 01:19 PM   #9
That could definitely be the iac, normally if you unplug it it should drop and almost die
Sent from my LG-D800 using Mustang Evolution mobile app
Old 01-26-2015, 07:25 PM   #10
2vhulk's Avatar
I'll fix it tomorrow then
Old 01-27-2015, 10:22 AM   #11
Panther140's Avatar
It could also possibly be your fuel pump. If it happens on a WOT pull, the pump may not be keeping up with the fuel pressure demand. That could be caused by a worn pump, couldn't it?
Old 01-27-2015, 06:11 PM   #12
2vhulk's Avatar
Yes!!!!! About that!! Everytime I do a WOT pull when i release it it dies on me
Old 01-27-2015, 06:14 PM   #13
Do a fuel pressure test also.
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
The guy turned in his Car Title and I want to buy his car. How do I get a new Title for the car? stanley General Car Discussion 2 04-10-2010 09:45 AM
Car problems continue,Speedo' problem Dark02Pony Pre-2005 V6 Mustang 4 09-22-2005 12:19 PM
Car wash problem.... douGT The Bar 15 03-28-2005 12:27 PM
04:00 AM
